8 1/4
#2904311
03/30/21 03:22 PM
03/30/21 03:22 PM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
HI anyone use a 8 1/4 rear 4:56-4:88 for drag racing with slicks 4000lb car? 400-500 hp mark Williams can make axles for me 27 spline thanks gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: 8 1/4
[Re: DusterKid]
#2904316
03/30/21 03:32 PM
03/30/21 03:32 PM
440lebaron
westerly, ri. usa
using for nhra stock, can get S60 from doctor diff, kinda heavy plus takes extra hp to turn
Re: 8 1/4
[Re: 440lebaron]
#2904318
03/30/21 03:38 PM
03/30/21 03:38 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
using for nhra stock, can get S60 from doctor diff, kinda heavy plus takes extra hp to turn But you'll never break it.
Re: 8 1/4
[Re: lancer493]
#2904397
03/30/21 09:03 PM
03/30/21 09:03 PM
440lebaron
westerly, ri. usa
Legal super/stock, stock no needs to be same make as body
Re: 8 1/4
[Re: 440lebaron]
#2904400
03/30/21 09:17 PM
03/30/21 09:17 PM
440lebaron
westerly, ri. usa
I can deal with changing ring and pinion each season as maintenance, just don't want to spit out pinion on starting line
Re: 8 1/4
[Re: 440lebaron]
#2904488
03/31/21 09:12 AM
03/31/21 09:12 AM
an8sec70cuda
What about an 8.75? Those can be had for cheap. I'd feel much more confident w/ that.
Re: 8 1/4
[Re: 440lebaron]
#2904899
04/01/21 12:10 PM
04/01/21 12:10 PM
Posts: 5,894 Florida
Locomotion
Saw your thread on classracer.com too.
I believe you would have to get a c-clip eliminator for the 8 1/4" rear because I'm pretty sure they are illegal (unsafe) under NHRA rules.
As mentioned by others, a Dana 60 won't slow you down much, if any at all. Most people I've heard commenting on the change didn't lose anything and some claimed to be slightly faster! It is a more efficient rear than the 8 3/4" (Takes less HP/torque to turn.) because of the location of the pinion contact relative to the ring gear. A Chevy 12 & 10 bolt are more efficient and a Ford 9" is the worst, but of course they aren't legal. 81/4" might be pretty efficient, but weaker, minimal ratio choices and fewer aftermarket parts. Overall weight is really irrelevant because the car has to be run at a minimum weight with driver anyway. Plus, the weight is in the back where it will do the most good. When you start replacing internal parts with aftermarket pieces that are lighter, the weight difference between a Dana 60 and 8 3/4" shrinks - (i.e.:lightened ring gear & spool, ) because the Dana 60 parts weigh more to begin with. Axles can be drilled and lightened in the flange area in either type. You also don't need a back-brace for a Dana 60 like you should have for an 8 3/4", bringing the 2 even closer in weight. Only down sides I see is that you need to get the gear ratio correct the first time and swapping gears is not as easy. Easier to get PRO gears for a Dana 60 as well. But either can have cryo and/or Superfinishing done for longer life.
I believe in the benefits of a Dana 60 enough to have installed one in my K/SA Aspen Wagon.with a 360 at a minimum weight of 3,927 starting out in the 12's! Got one for my trusty Dart Sport @ 3,530 minimum weight for IHRA Stock capable of low 11's. But that one hasn't been installed yet and don't know if I'll be out with either one anyway.
Get a Dana 60. It will be better and cheaper in the long run.
