Zinc in oil? #290317
04/16/09 02:08 PM
04/16/09 02:08 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Mopar Performance says to use oil with zinc in it to protect their camshafts (purple shaft), but most oils today don't have zinc. Is there a zinc additive available anywhere, and just how important is this? Thanks!
Re: Zinc in oil? [Re: polkat] #290318
04/16/09 02:43 PM
04/16/09 02:43 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
Very important on initial startup to break in a cam.
I use comp cam additive part# 159.
And also if you want to keep a little zinc in your oil.The STP additive is 75% Zinc.
Re: Zinc in oil? [Re: sc301v] #290319
04/16/09 03:01 PM
04/16/09 03:01 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
STP? really? which one?
Re: Zinc in oil? [Re: polkat] #290320
04/16/09 03:38 PM
04/16/09 03:38 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
I run a MP cam and I use Bradd Penn break in oil with a bottle of GM EOS, and have never had any problems with cam wear.Actually I put the EOS in with every oil change You should be able to get the EOS at any GM dealership.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Zinc in oil? [Re: racerAL] #290321
04/16/09 03:42 PM
04/16/09 03:42 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Re: Zinc in oil? [Re: challenger70] #290322
04/16/09 05:02 PM
04/16/09 05:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Don't know if it has zinc...but I got a bottle of Rislone. Where would it say on the bottle or would it? It claims to be for performace applications, protects engine parts and stablizes oil....it's blue and realllly thick. Kind of like old school STP oil treatment.
Coming soon!!!!
Re: Zinc in oil? [Re: Mr.Yuck] #290323
04/16/09 05:08 PM
04/16/09 05:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
don't know what any of this means but it's form the Rislone web page.
TEST ASTM TYPICAL PROPERTIES
API Gravity @ 15.6°C D-1298 27.1
Specific Gravity @ 15.6°C D-4052 0.8915
Density @15.6°C D-1298 7.317
Flash Point D-92 210°C / 410°F
Viscosity, cSt. @ 40°C D-445 1721
Viscosity, cSt. @ 100°C D-445 135
Viscosity, cSt. @ 150°C D-445 41
Viscosity Index D-445 n/a
Pour Point °C D-97 -21
Re: Zinc in oil? [Re: racerAL] #290324
04/16/09 07:23 PM
04/16/09 07:23 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Good luck finding EOS anymore. Here in the Seattle area I was told by the dealership parts guys that it is discontinued. He showed me a list of dealerships for 100 miles and the meager quantity of EOS each one had left in stock.
Re: Zinc in oil? [Re: Classof70Chally] #290325
04/16/09 07:34 PM
04/16/09 07:34 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
ist not called EOS anymore they changed the name to something like engine assembly lube or something but gm still sells it
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Zinc in oil? [Re: dusturbd340W5] #290326
04/16/09 07:40 PM
04/16/09 07:40 PM
JOE GIBBS BREAK IN OIL AND HOT ROD OIL
All that needs to be said on this topic ever again
Available mail order from a zillion different places
WORKS PERIOD!
Problem has been solved gang--get on board
No additives--no guessing --no problems
Now... if you could just build an engine out of a block that did not have 40 year old lifter bores...............
Re: Zinc in oil? [Re: ] #290327
04/16/09 08:12 PM
04/16/09 08:12 PM
Idaho
Runner Offline
Runner  Offline
Idaho
WORKS PERIOD!
my problem with it is the insane price, and its mail order only.
Re: Zinc in oil? [Re: Runner] #290328
04/16/09 08:19 PM
04/16/09 08:19 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Buy your favorite viscosity oil and put a bottle of Comp #159 in.
Re: Zinc in oil? [Re: 10.90 Racer] #290329
04/16/09 08:32 PM
04/16/09 08:32 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Well, since I started this topic, I've done a bit of research on zinc in oil. here are a few websites with good info...
www.aera.org/eptb/TB2333R.pdf
http://www.automachperf.com/breakin.html
http://www.powerperformancenews.com/forum/new-tech-bulletin-flat-tappet-camshaft-10.html
Seems that zinc is very important in breakin and regular running for flat tappet cams. I've heard a lot of additive names here but not which ones contain zinc. Who can enlighten me? Thanks!
Re: Zinc in oil? [Re: polkat] #290330
04/16/09 08:39 PM
04/16/09 08:39 PM
Kirkland, Washington
Pacnorthcuda Offline
Look up ZDDPlus. Its a relatively newcomer to the scene develeped specifically for the reduced ZN oils of today. The ppm in the little 4 oz bottle is 71,000.......yep 71,000. That boosts the level WAY up in a 5-6 quart fill (do the math).
There ARE safe oil choices too, some are synthetic--redline, amsoil, royal purple, some not like Brad Penn, and diesel oils like Delo and Rotella
Re: Zinc in oil? [Re: Pacnorthcuda] #290331
04/16/09 10:01 PM
04/16/09 10:01 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
“Motor oils are carefully balance by the formulator/manufacturer and tested to verify compliance with appropriate specifications. Adding aftermarket additives to these oils may upset this balance and the results may be unpredictable. If you trust the technology of the manufacturer, then it would be prudent to leave his formulation alone.” – Tom Schaefer, retired vice president of sales and marketing for Hatco Corporation.
An unpredictable behavior of a motor oil with an aftermarket oil additive could lead to foaming tendencies as shown in this LINK
CompSyn
Re: Zinc in oil? [Re: Blown61] #290332
04/17/09 10:03 AM
04/17/09 10:03 AM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
Just the old STP..Part# 65148...contains 25% olefin copolymer and 75% Zinc
Re: Zinc in oil? [Re: sc301v] #290333
04/17/09 10:28 AM
04/17/09 10:28 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Or the red bottle which has a bunch of zinc but is thinner than the blue bottle stuff.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Zinc in oil? [Re: CompSyn] #290334
04/17/09 11:54 AM
04/17/09 11:54 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
so we listen to marketing guy at a company we never heard of?
CompSyn
Re: Zinc in oil? [Re: 05dakota] #290335
04/17/09 08:58 PM
04/17/09 08:58 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
CompSyn
Hatco Corporation, is known for its advanced synthetic lubricants for aviation, refrigeration, industrial and automotive. Many oil companies purchase base oils from Hatco. In fact, the motor oil that’s in your car right now may have been influenced by Hatco in some way or another.
About Hatco Corporation - link
Re: Zinc in oil? [Re: CompSyn] #290336
04/18/09 12:29 AM
04/18/09 12:29 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
So if one adds a bottle or can of STP to a new oil change...say in a 383 or 400, what will the zinc count be? From what I've read above, 1200 should be the minimum. Will STP do that?
