Re: Zinc in oil?
[Re: sc301v]
#290319
04/16/09 03:01 PM
04/16/09 03:01 PM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
Very important on initial startup to break in a cam.
I use comp cam additive part# 159.
And also if you want to keep a little zinc in your oil.The STP additive is 75% Zinc.
STP? really? which one?
Re: Zinc in oil?
[Re: polkat]
#290320
04/16/09 03:38 PM
04/16/09 03:38 PM
Posts: 535 Ohio
racerAL
Ohio
I run a MP cam and I use Bradd Penn break in oil with a bottle of GM EOS, and have never had any problems with cam wear.Actually I put the EOS in with every oil change You should be able to get the EOS at any GM dealership.
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
Re: Zinc in oil?
[Re: racerAL]
#290324
04/16/09 07:23 PM
04/16/09 07:23 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
Good luck finding EOS anymore. Here in the Seattle area I was told by the dealership parts guys that it is discontinued. He showed me a list of dealerships for 100 miles and the meager quantity of EOS each one had left in stock.
Re: Zinc in oil?
[Re: Classof70Chally]
#290325
04/16/09 07:34 PM
04/16/09 07:34 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
ist not called EOS anymore they changed the name to something like engine assembly lube or something but gm still sells it
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Zinc in oil?
[Re: dusturbd340W5]
#290326
04/16/09 07:40 PM
04/16/09 07:40 PM
JOE GIBBS BREAK IN OIL AND HOT ROD OIL All that needs to be said on this topic ever again Available mail order from a zillion different places WORKS PERIOD! Problem has been solved gang--get on board No additives--no guessing --no problems
Now... if you could just build an engine out of a block that did not have 40 year old lifter bores...............
Re: Zinc in oil?
[Re: ]
#290327
04/16/09 08:12 PM
04/16/09 08:12 PM
Posts: 3,095 Idaho
Runner
Idaho
my problem with it is the insane price, and its mail order only.
Re: Zinc in oil?
[Re: polkat]
#290330
04/16/09 08:39 PM
04/16/09 08:39 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
Look up ZDDPlus. Its a relatively newcomer to the scene develeped specifically for the reduced ZN oils of today. The ppm in the little 4 oz bottle is 71,000.......yep 71,000. That boosts the level WAY up in a 5-6 quart fill (do the math).
There ARE safe oil choices too, some are synthetic--redline, amsoil, royal purple, some not like Brad Penn, and diesel oils like Delo and Rotella
Re: Zinc in oil?
[Re: Pacnorthcuda]
#290331
04/16/09 10:01 PM
04/16/09 10:01 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
“Motor oils are carefully balance by the formulator/manufacturer and tested to verify compliance with appropriate specifications. Adding aftermarket additives to these oils may upset this balance and the results may be unpredictable. If you trust the technology of the manufacturer, then it would be prudent to leave his formulation alone.” – Tom Schaefer, retired vice president of sales and marketing for Hatco Corporation. An unpredictable behavior of a motor oil with an aftermarket oil additive could lead to foaming tendencies as shown in this LINK CompSyn
Re: Zinc in oil?
[Re: Blown61]
#290332
04/17/09 10:03 AM
04/17/09 10:03 AM
Posts: 364 Kentucky
sc301v
Kentucky
Just the old STP..Part# 65148...contains 25% olefin copolymer and 75% Zinc
Re: Zinc in oil?
[Re: sc301v]
#290333
04/17/09 10:28 AM
04/17/09 10:28 AM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Or the red bottle which has a bunch of zinc but is thinner than the blue bottle stuff.
Re: Zinc in oil?
[Re: 05dakota]
#290335
04/17/09 08:58 PM
04/17/09 08:58 PM
CompSyn
Pacific NW USA
so we listen to marketing guy at a company we never heard of?
CompSyn
Hatco Corporation, is known for its advanced synthetic lubricants for aviation, refrigeration, industrial and automotive. Many oil companies purchase base oils from Hatco. In fact, the motor oil that’s in your car right now may have been influenced by Hatco in some way or another.
About Hatco Corporation - link
Re: Zinc in oil?
[Re: rowin4]
#290338
04/18/09 02:28 PM
04/18/09 02:28 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Use a can of EOS from a gm dealer for break in if you can find it, my GM dealer said they haven't handled it in years.
posted above--they still have it--new name/ part #
