Pistol grip shifter #290292
04/16/09 01:34 PM
04/16/09 01:34 PM
naples fl
70 v code Offline OP
naples fl
How do you remove the shifter handle from the shifter?
Re: Pistol grip shifter [Re: 70 v code] #290293
04/16/09 01:42 PM
04/16/09 01:42 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
If it's the factory set-up, you shove a feeler gauge bewteen the left side of the rectangular hole where the handle goes and the handle. This releases the retaining tabs and the handle slides up.
The procedure is in the FSM (read it, learn it, live it)
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Pistol grip shifter [Re: Hrtbkr] #290294
04/16/09 01:49 PM
04/16/09 01:49 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Use a .010 feeler and maybe shoot a little WD40 down there. If it has never been removed before from the socket, it can be REALLY tough to get it out...
Re: Pistol grip shifter [Re: 70 v code] #290295
04/16/09 04:15 PM
04/16/09 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Push down firmly on the handle while inserting the feeler gauge, this relieves the tension on the lock tab.
Re: Pistol grip shifter [Re: John_Kunkel] #290296
04/16/09 04:48 PM
04/16/09 04:48 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From the FSM, get one.
Re: Pistol grip shifter [Re: Snoopy] #290297
04/16/09 09:02 PM
04/16/09 09:02 PM
naples fl
naples fl
got it out needed to clean all road grime out 1st!
