Aluminum Blocks and 440 Source Cranks #2901695
03/22/21 04:48 PM
03/22/21 04:48 PM
Indiana
W5Duster436 Offline OP
Indiana
All,
Been an awfully LONG time since i've been on here but was chatting with a friend who's adamant he needs to run a 6k dollar aluminum block on the street and wanted to get some feedback from the guru's on this as maybe i'm completely off-base on this nowadays and gave him bad information. The other issue is he wants to run a 440 Source crank and also wondered what the general concensus is on those these days. I can recall years ago that their reputation was less than stellar. I guess my feeling is that if I'm hell bent on running a 6k aluminum block on the street, I'm going to run Callies, Kellogg etc. Am i completely off base here? :-)
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Aluminum Blocks and 440 Source Cranks [Re: W5Duster436] #2901719
03/22/21 05:42 PM
03/22/21 05:42 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Nothing wrong with a 440Source crank...We have a ton of them in street cars and race cars....zero issues with their rotating assemblies either..
Re: Aluminum Blocks and 440 Source Cranks [Re: Dragula] #2901750
03/22/21 07:35 PM
03/22/21 07:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Most of the bad rap is from China haters who continuously overexaggerate a minor issue. However, I can't help wonder why you'd want to put a budget crank in a premium block !!!
Re: Aluminum Blocks and 440 Source Cranks [Re: Stanton] #2901760
03/22/21 07:54 PM
03/22/21 07:54 PM
New York
polyspheric Online content
polyspheric  Online Content
New York
What makes a China hater:
1. has a job
2. pays taxes
3. does not get his political views from CNN
Boffin Emeritus
Re: Aluminum Blocks and 440 Source Cranks [Re: polyspheric] #2901802
03/22/21 09:19 PM
03/22/21 09:19 PM
NY
B1duster Offline
B1duster  Offline
NY
1. has a job
2. pays taxes
I’m with you !
Re: Aluminum Blocks and 440 Source Cranks [Re: B1duster] #2901804
03/22/21 09:23 PM
03/22/21 09:23 PM
NY
B1duster Offline
B1duster  Offline
NY
Tell your buddy he should at a minimum be using Molnar
crank and rods in his $6k block. Only a couple hundred bucks
more, nicer stuff and better resale
Re: Aluminum Blocks and 440 Source Cranks [Re: B1duster] #2901811
03/22/21 10:05 PM
03/22/21 10:05 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's how I roll
Re: Aluminum Blocks and 440 Source Cranks [Re: FastmOp] #2901831
03/22/21 11:09 PM
03/22/21 11:09 PM
PA
moparacer Offline
moparacer  Offline
PA
Quote
more, nicer stuff and better resale...
This....Everyday and twice on Sundays!
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Aluminum Blocks and 440 Source Cranks [Re: FastmOp] #2901832
03/22/21 11:11 PM
03/22/21 11:11 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Think of other less expensive equivalents...........would you have your heads ported and run stock springs ?
Adapter and dominator on an iron intake ?
Cast pistons and Carillo rods ?
The cool factor of an aluminum block is way up there.
But if you are willing to open up the vault , keep it open.
Hell , I don't even skimp on gaskets.
There are better off shore options , as mentioned.
But pairing the best with the marginal just baffles me.
Re: Aluminum Blocks and 440 Source Cranks [Re: Stanton] #2901834
03/22/21 11:15 PM
03/22/21 11:15 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Crankshafts are a minor issue.
Funding the second largest blue water Navy is another matter entirely.
I honestly think that we are buying the rope to hang ourselves.
And I don't have money falling out of every orifice by any means.
I do get saving a few bucks where it makes sense.
This doesn't make any sense at all.
Re: Aluminum Blocks and 440 Source Cranks [Re: W5Duster436] #2901837
03/22/21 11:19 PM
03/22/21 11:19 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted by W5Duster436
All,
If he wants to spend 6 large for a block and fill it with 440 Source parts, [censored] it, it's his money shruggy All of it should be sent to a reliable machine shop to be checked and corrected as necessary.
Re: Aluminum Blocks and 440 Source Cranks [Re: Skeptic] #2901860
03/23/21 01:21 AM
03/23/21 01:21 AM
gregsdart Offline
gregsdart  Offline
All the crank has to do is match the stress level it will live with. Its a long stretch from a small port torque build to B1 heads and 8000 rpm. Or a blown app.
Re: Aluminum Blocks and 440 Source Cranks [Re: gregsdart] #2901875
03/23/21 06:07 AM
03/23/21 06:07 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I been 162MPH in the 1/8 with this exact combo ha ha ha ha. Turn it 7500 every pass.
Save your $$$$ for rods and pistons.
I need some sponsorship from 440Source lol
Re: Aluminum Blocks and 440 Source Cranks [Re: FastmOp] #2901881
03/23/21 07:28 AM
03/23/21 07:28 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Having used quite a few 440 source cranks I have never had any failures making up to over 800 hp in a few.
The problem is the machining. having to send them out to get skinned to get bearing clearances corrected and snout clearanced so dampner had correct press fit is the issue. so you take what you spend to fix you could buy a better machined crank . Never had any issues with a molnar.
JAKES AUTOMOTIVE
Re: Aluminum Blocks and 440 Source Cranks [Re: B1duster] #2901942
03/23/21 10:37 AM
03/23/21 10:37 AM
Nevada
merpar Offline
merpar  Offline
Nevada
Molnar cranks, Eagle, Scat, and several others are ALL from China. And I would guess from the same supplier. So just take your pick.
Re: Aluminum Blocks and 440 Source Cranks [Re: B1duster] #2902009
03/23/21 12:29 PM
03/23/21 12:29 PM
NC
440Jim Offline
440Jim  Offline
NC
That is what I was thinking.
I am fine with 440source stuff in a mild street build on a budget. Or even a 650 hp bracket motor...
Re: Aluminum Blocks and 440 Source Cranks [Re: JAKE68] #2902013
03/23/21 12:34 PM
03/23/21 12:34 PM
NC
440Jim Offline
440Jim  Offline
NC
Yup, about the same cost after paying for "adjustments"
Re: Aluminum Blocks and 440 Source Cranks [Re: 440Jim] #2902034
03/23/21 01:25 PM
03/23/21 01:25 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'll just leave this here for 440Source to see
Re: Aluminum Blocks and 440 Source Cranks [Re: merpar] #2902039
03/23/21 01:38 PM
03/23/21 01:38 PM
an8sec70cuda Offline
iagree From the one's I've seen, the finish machining differs from brand to brand, even though they are all very similar (same?) forgings from overseas.
I've done engines w/ Scat, Callies cheaper line Comp Star series, K1, and Molnar products and they needed nothing but balancing to be used.
Eagle, on the other hand, needs some machining before being installed.
I've never used any of 440 source's bottom end components.
I feel better buying something new that doesn't need to be "rebuilt" first.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aluminum Blocks and 440 Source Cranks [Re: W5Duster436] #2902117
03/23/21 05:01 PM
03/23/21 05:01 PM
I bought a older used KB top fuel 4.500 stroke crank with Mopar rod journals that is fully counterweighted, it had 4 cracks in it so I sent it to David at Marine Crankshafts (714-549-2388) to have them grind the cracks out and weld it back up and make it reusable. I'm going to use it in my new KB 4.500 bore wedge block to see if I can make 800+HP on pump gas with a set of B1 heads luck
On your deal how hard are you going to stress this new motor? More stress needs better parts uptwocents
