67 GTX Conv. rear window zipper problem #290211
04/16/09 11:05 AM
04/16/09 11:05 AM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
Took the car out last night, was a bit chilly so put the top up and was zipping the rear window in place and the portion of zipper opened behind the zipper unit that you zip up the zipper with. Now I can not unzip. Window is 1/4 closed. I don't want to force it back and was wondering what ideas you have. thanks
1971 340 Swinger Canadian Car
1972 Dodge Dart Prostreet 440
2013 Dodge Ram 1500
Re: 67 GTX Conv. rear window zipper problem [Re: dalei989] #290212
04/17/09 12:18 PM
04/17/09 12:18 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I gotta think that you messed up your zipper permanently..
OT here, R U supposed to unzip and lay the rear window down when you lower your vert top??
Re: 67 GTX Conv. rear window zipper problem [Re: dalei989] #290213
04/17/09 12:42 PM
04/17/09 12:42 PM
Andrewh Offline
Andrewh  Offline
Should not be a problem to force it back. Run a bar of dry soap over it to lube it up a bit and support the seams if the top is old, just becareful.
Just like if your jacket or pants zipper opened up from the wrong side.
