Which master with wilwood brakes #2900204
03/17/21 08:56 PM
03/17/21 08:56 PM
junction city oregon
V
viperblue72 Offline OP
V
I have a 74 cuda with factory power discs. I just bought the wilwood brake kit with the 12” rotor. Wilwood quoted me which of theirs to use but it’s $350. Is there any other options with a smaller bore? I plan to run just manual brakes.
Re: Which master with wilwood brakes [Re: viperblue72] #2900250
03/18/21 01:53 AM
03/18/21 01:53 AM
What size bore did they say to buy for your deal?
My Cuda has dual Wilwood master cylinders with a balance bar mounted under the floor, dual Wilwood calipers on the rear with the same size single calipers on the front.
I replace both M.C. and all the pads two years ago to be safe, I don't remember their M.C. being that expensive back then confused
I can look at the old ones in the morning to see if there is a part number on them to see what size bore they are if you want to find out which size mine are.
I think my rotors are either 11 or 12 inch diameter max, not the bigger road racing ones.
Re: Which master with wilwood brakes [Re: Cab_Burge] #2900262
03/18/21 06:47 AM
03/18/21 06:47 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Dr. Diff has some options that are priced well and work good. I run wilwood brakes all the way around with one of his master cylinder kits. Way less than $350
68 Barracuda Formula S 340
Re: Which master with wilwood brakes [Re: viperblue72] #2900303
03/18/21 10:05 AM
03/18/21 10:05 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have Wilwood disc brakes on all four corners of my 64 dodge, and I used a master cylinder from an 1989 Ramcharger to my memory. It looks exactly like the masters Wilwood offers. I just browsed in the parts book at the local parts store for the bore size I wanted.
Re: Which master with wilwood brakes [Re: jwb123] #2900375
03/18/21 01:42 PM
03/18/21 01:42 PM
V
V
DoctorDiff hooked me up with a 15/16 bore master and all I need for around $200. Thanks guys.
Re: Which master with wilwood brakes [Re: viperblue72] #2900398
03/18/21 02:25 PM
03/18/21 02:25 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
On my cuda I went thru mancini. Picked up a 1.032 bore. I'm using wildwood 12.19 fronts and 11" rears(if I remember the rear size, ive had them since 1988). The fronts are a new addition. Car hasn't been to the track yet as the engine isn't completed.
Ok
Re: Which master with wilwood brakes [Re: cudatom] #2900426
03/18/21 03:35 PM
03/18/21 03:35 PM
MN
W
Willie68coronet Offline
W
MN
I have wilwood 11" disc on my front and 10" stock rear drums with manual brakes and ordered the 15/16" from dr diff as he recommended for me. Pedal has a good feel
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: Which master with wilwood brakes [Re: viperblue72] #2900464
03/18/21 05:32 PM
03/18/21 05:32 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
https://www.dragstuff.com/techarticles/RacingMasterCylPN.html 24 mm is 15/16 i have on both my cars works great and costs about $28
Re: Which master with wilwood brakes [Re: cudatom] #2900723
03/19/21 01:17 PM
03/19/21 01:17 PM
V
V
I ordered the same fronts but will have a 10” drum on the rear.
Cab, I lost the part number for the master they recommended but it was billet aluminum and 15/16 bore, with a proportioning valve seperate and a 10% reducer since I don’t have rear disc yet. But the master alone was $345
Re: Which master with wilwood brakes [Re: plycuda] #2900777
03/19/21 02:40 PM
03/19/21 02:40 PM
moparx Offline
moparx  Offline
the one thing to remember about using the front drive masters, they were all power brake masters, therefore, they don't have a means to retain a manual brake pushrod.
you will have to machine the rear piston for the rubber retainer, or fab a positive stop to make sure the pedal pushrod won't fall out, causing a bad day for sure.........
beer
Re: Which master with wilwood brakes [Re: moparx] #2900824
03/19/21 04:09 PM
03/19/21 04:09 PM
BDW Online content
BDW  Online Content
Check rock auto, or local parts store, these are only $40 and have lifetime warranty
