Re: Which master with wilwood brakes
[Re: viperblue72]
#2900250
03/18/21 01:53 AM
03/18/21 01:53 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
What size bore did they say to buy for your deal? My Cuda has dual Wilwood master cylinders with a balance bar mounted under the floor, dual Wilwood calipers on the rear with the same size single calipers on the front. I replace both M.C. and all the pads two years ago to be safe, I don't remember their M.C. being that expensive back then I can look at the old ones in the morning to see if there is a part number on them to see what size bore they are if you want to find out which size mine are. I think my rotors are either 11 or 12 inch diameter max, not the bigger road racing ones.
[Re: Cab_Burge]
#2900262
03/18/21 06:47 AM
03/18/21 06:47 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Dr. Diff has some options that are priced well and work good. I run wilwood brakes all the way around with one of his master cylinder kits. Way less than $350
68 Barracuda Formula S 340
[Re: viperblue72]
#2900398
03/18/21 02:25 PM
03/18/21 02:25 PM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
On my cuda I went thru mancini. Picked up a 1.032 bore. I'm using wildwood 12.19 fronts and 11" rears(if I remember the rear size, ive had them since 1988). The fronts are a new addition. Car hasn't been to the track yet as the engine isn't completed.
Ok
[Re: cudatom]
#2900426
03/18/21 03:35 PM
03/18/21 03:35 PM
Posts: 277 MN
Willie68coronet
MN
I have wilwood 11" disc on my front and 10" stock rear drums with manual brakes and ordered the 15/16" from dr diff as he recommended for me. Pedal has a good feel
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: cudatom]
#2900723
03/19/21 01:17 PM
03/19/21 01:17 PM
Posts: 2,141 junction city oregon
viperblue72
I ordered the same fronts but will have a 10” drum on the rear. Cab, I lost the part number for the master they recommended but it was billet aluminum and 15/16 bore, with a proportioning valve seperate and a 10% reducer since I don’t have rear disc yet. But the master alone was $345
