Performer RPM Intake and Stock Exhaust Manifolds
#2900614
03/19/21 07:37 AM
03/19/21 07:37 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Another question. I'm building a 383/438 stroker for my customers 68 Charger that has the stock hood. Would I be wasting my time going with the Edelbrock Performer RPM intake if I am using the stock factory exhaust manifolds? Should I just go with an Edelbrock Performer intake?
Thanks Darren
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
Re: Performer RPM Intake and Stock Exhaust Manifolds
[Re: ChrgrCuda]
#2900647
03/19/21 09:50 AM
03/19/21 09:50 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Unless what you’re building is very mild, the RPM should be better.
[Re: fast68plymouth]
#2900666
03/19/21 11:14 AM
03/19/21 11:14 AM
Posts: 910 West Virginia
B1Frank
West Virginia
I have a 446 inch 440, and i like the RPM manifold, and i have used them all ! ..............great manifold for a duel plane.......i would use it with stock manifolds. for the street
[Re: ChrgrCuda]
#2900826
03/19/21 04:41 PM
03/19/21 04:41 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If you're worried about the RPM being choked by the exhaust you can relax a bit. It's a distinct improvement over the non-RPM on most motors regardless of exhaust used. Granted, better exhaust would help but you're not at the point where the exhaust will cancel out intake improvements.
[Re: ChrgrCuda]
#2900912
03/19/21 08:59 PM
03/19/21 08:59 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Generally speaking, if your manifold motor is in the 425 HP rrange, the regular Performer or CH4B are fine. After that, there will be some power advantage to the RPM. Also the Performer and CH4B will do better over 425 HP with the divider milled down.
[Re: BSB67]
#2901492
03/22/21 08:06 AM
03/22/21 08:06 AM
ChrgrCuda
Texas, USA
Thanks everyone for the feedback. After speaking with Dwayne Porter I think we are going with the RPM and a Lunati Voodoo cam for this build. Thanks again!
