Cam Suggestions for 383/431 Stroker #2899610
03/16/21 10:24 AM
03/16/21 10:24 AM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Any suggestions on a hydraulic flat tappet cam for a 383/431 stroker with fuel injection? Currently the car has a tired 440 with a FiTech TB system, and wants me to build his original 383 to put back in the Charger and use the 440 for a future E-body project. I'm thinking something with a 112 LSA to be EFI friendly, however open to suggestions.
Darren
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Cam Suggestions for 383/431 Stroker [Re: ChrgrCuda] #2899641
03/16/21 11:31 AM
03/16/21 11:31 AM
AndyF Online content
AndyF  Online Content
Probably something in the 230's @ 050. The 112 LCA would help keep the vacuum up which makes the system a little easier to tune and drive.
Re: Cam Suggestions for 383/431 Stroker [Re: AndyF] #2899670
03/16/21 12:45 PM
03/16/21 12:45 PM
Texas, USA
Texas, USA
Thanks Andy!!
Re: Cam Suggestions for 383/431 Stroker [Re: ChrgrCuda] #2899743
03/16/21 03:27 PM
03/16/21 03:27 PM
Check out the hyd flat tappet cam that I used in this cam test. That cam might be a little too aggressive for a daily driver but it sure worked great in my low deck stroker. http://www.moparts.org/Tech/Archive/bb/Lobe.html
Of course if I was building an engine today and I wanted a cam I'd call Dwayne and have him spec me a cam and spring combo.
Re: Cam Suggestions for 383/431 Stroker [Re: ChrgrCuda] #2899808
03/16/21 06:21 PM
03/16/21 06:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If you're not fixed on TB, you can use a much bigger cam.
Boffin Emeritus
Re: Cam Suggestions for 383/431 Stroker [Re: ChrgrCuda] #2899888
03/16/21 10:12 PM
03/16/21 10:12 PM
NY
B1duster Offline
B1duster  Offline
NY
Re: Cam Suggestions for 383/431 Stroker [Re: B1duster] #2899964
03/17/21 07:39 AM
03/17/21 07:39 AM
Texas, USA
Texas, USA
Thanks everyone. I agree a roller would be better, however this car will have exhaust manifolds and he wants his EFI on the new engine. Trying to decide if I can get an Edelbrock RPM intake under the stock hood with the stock air cleaner, but looks like it may not fit.
Re: Cam Suggestions for 383/431 Stroker [Re: ChrgrCuda] #2899986
03/17/21 09:18 AM
03/17/21 09:18 AM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
I know this is a SFT cam. But a HYD cam in this range would work nice I would think. This is the cam DP spec'd for my build for my intended use [Linked Image]
Re: Cam Suggestions for 383/431 Stroker [Re: HDNMOPERS] #2900062
03/17/21 01:16 PM
03/17/21 01:16 PM
Texas, USA
Texas, USA
Very nice. One thing that needs to be kept in mind is that it needs to have enough vacuum for power brakes.
Re: Cam Suggestions for 383/431 Stroker [Re: ChrgrCuda] #2900093
03/17/21 02:48 PM
03/17/21 02:48 PM
The idle speed in gear will have a lot to do with how much vacuum the motor will have at a given RPM, idling at 800 RPM in gear will have less vacuum than idling at 1000 RPM in gear, been there done that shruggy
My old pump gas Duster had a decent (260@.050 intake and 266@.050 on the exhaust) solid roller camshaft in it ground on a 108 LSA installed at 107 degrees in the intake lobes, it would idle at 4.0 to 4.5 inches of vacuum at 850 RPM in gear and have right at 10.0 inches at 1000 RPM in gear shruggy It was not as nasty sounding idling at 850 RPM as it was at 1000 RPM shruggy
It was really raspy sounding at 1700 RPM in gear driving with light part throttle with around 16.0 inches of vacuum whiney shruggy
Re: Cam Suggestions for 383/431 Stroker [Re: Cab_Burge] #2900171
03/17/21 06:44 PM
03/17/21 06:44 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
My 71 Bee has factory power brakes
383/432 Stroker Auto
I run the Comp XE275 HL
E Street 75cc Heads - 10.5 Compression
12"-13" of vacuum at 700 Rpms Idle
Zero issues
Motor would idle at 500 Rpms if i wanted
800 AVS-2 is flawless off idle - I love this carb
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Cam Suggestions for 383/431 Stroker [Re: bee1971] #2900309
03/18/21 10:22 AM
03/18/21 10:22 AM
Texas, USA
Texas, USA
Zero issues
Thanks for the feedback. How do you like your 383 stroker combo? Any dyno numbers?
