Head gasket bore, vs. Cylinder wall bore
#2897345
03/09/21 11:57 AM
03/09/21 11:57 AM
Posts: 10,039 MN
JERICOGTX
MN
Looking at gaskets for my INDY aluminum block, and Cometic makes a 4.530 bore gasket, and my block is 4.524. Is this too close to use? Should I use a bigger bore gasket? Never had a gasket that close to the cylinder wall before.
69 GTX
68 Road Runner
Re: Head gasket bore, vs. Cylinder wall bore
[Re: cl440]
#2897415
03/09/21 03:49 PM
03/09/21 03:49 PM
Posts: 43,251 Bend,OR USA
Cab_Burge
May want to consider a gasket with a larger bore. I would use a 4.550 bore size gaskets
[Re: Cab_Burge]
#2897434
03/09/21 04:44 PM
03/09/21 04:44 PM
Posts: 2,666 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
May want to consider a gasket with a larger bore. I would use a 4.550 bore size gaskets I agree with Cab. I think Cometic told me .015"-.030" back from the bore.
2011 Drag Pak Challenger
[Re: rickseeman]
#2897437
03/09/21 04:55 PM
03/09/21 04:55 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
May want to consider a gasket with a larger bore. I would use a 4.550 bore size gaskets I agree with Cab. I think Cometic told me .015"-.030" back from the bore. .030" larger bore is what I've always heard recommended.
[Re: an8sec70cuda]
#2897583
03/09/21 11:27 PM
03/09/21 11:27 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Its funny. The Felpro 1009 is advertised at 4.410 but the fire ring is almost in the bore of my 4.375 motor! Always Check!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
