CHECKING REAR FOR STRAIGHT #2896779
03/07/21 02:46 PM
03/07/21 02:46 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
8 3/4 that I will start to prep for use. How do I check for straight. The rear is fully assembled less brakes
Re: CHECKING REAR FOR STRAIGHT [Re: A/MP] #2896800
03/07/21 03:46 PM
03/07/21 03:46 PM
AndyF Offline
AndyF  Offline
Depends what you mean by straight. Also depends on what tools you have or are willing to buy.
Re: CHECKING REAR FOR STRAIGHT [Re: A/MP] #2896806
03/07/21 04:06 PM
03/07/21 04:06 PM
I use two carpenter squares and a tape measure , have some one hold one of the squares against the axle flange, no brake drum or rotor on the axles and measure out around 15 inches from the center of the axles on both sides to the front side and see what you get, then do the same towards the rear and then if you can straight up and down. The stock wheel tubs limit how far you can measure straight up, what ever you can get use the same length measuring straight down wrenchscope
I like to see less than 1/8 inch variance front to back with the front being narrower for toe in, no variance straight up compared to straight down tsk
Please let us know what you do no mater what method you choose thumbs
Re: CHECKING REAR FOR STRAIGHT [Re: Cab_Burge] #2896814
03/07/21 04:32 PM
03/07/21 04:32 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Unbolt the axles, slide them in and out. Check for square, having to pull them one way or the other (likely back if its bent) to get them to slide in, and going in and out smoothly.
I've seen some hacked up narrow jobs with the ends on stupid crooked and the axles wouldn't even go in all the way.
Re: CHECKING REAR FOR STRAIGHT [Re: CMcAllister] #2896863
03/07/21 08:19 PM
03/07/21 08:19 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
2 jack stands ... roll it over with a dial indicators at the ends. that gets the housing checked.
Re: CHECKING REAR FOR STRAIGHT [Re: CMcAllister] #2897127
03/08/21 02:37 PM
03/08/21 02:37 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
THIS ^^^
....BAD A$$ STREET CAR.....
Re: CHECKING REAR FOR STRAIGHT [Re: n20mstr] #2897195
03/08/21 07:07 PM
03/08/21 07:07 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Being a cabinet maker, I thought about a straight edge on each flange and measure the diagonals for and aft of the housing in general. That work?
Re: CHECKING REAR FOR STRAIGHT [Re: A/MP] #2897199
03/08/21 07:12 PM
03/08/21 07:12 PM
Absolutely thumbs
I measured off the ends of the squares instead of across and over the housing, I like and use the KISS principles thumbs grin
Re: CHECKING REAR FOR STRAIGHT [Re: Cab_Burge] #2897225
03/08/21 09:05 PM
03/08/21 09:05 PM
A727Tflite Offline
A727Tflite  Offline
Great idea but worthless info until you have a specification to go against.
Use a 4’ long straight edge and it has 1/8” toe in versus a 1’ long straight edge and it has 1/8” in toe in.
That’s two different values in degrees of toe.
What’s the spec?
Now if you get zero in each case - you may be on to something. And that is assuming the ends were welded on square to the tubes.
In the OPs case, I would go with McAllister’s suggestion.
Starting from scratch - use an arbor and pucks.
Re: CHECKING REAR FOR STRAIGHT [Re: A727Tflite] #2897298
03/09/21 04:06 AM
03/09/21 04:06 AM
As I said I look for no more than 1/8 inch toe in on the front side 15 inches out from the axle centers, .060 narrower on the front and .060 wider on the back side, no difference between the top and bottom measurements. This is to check if the housing or axles are bent at all, I do rotate the axles 90 degrees to make sure if the width differences in the axles or the housing scope wrench
I bent the 1964 B body narrowed 8 3/4 housing in my old Duster bad enough that the right side axle wouldn't slide in and out without using a block of wood and a big hammer to drive them in hammer tsk realcrazy
Never again tsk
Re: CHECKING REAR FOR STRAIGHT [Re: Cab_Burge] #2897316
03/09/21 09:14 AM
03/09/21 09:14 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
The simplest and quickest way I have used for preliminary checking for straight is put a set of tires or even just rims on, while it is sitting on floor, rotate the housing around and you will see wheels move in and out as it is rotated. I have seen supposedly STRAIGHT housings that were done with the solid bar narrowing kits when welding still show quite a bit of wheels moving in and out as housing is rotated. Again, quick and simple, but definitely lets you know how straight..... or not!
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: CHECKING REAR FOR STRAIGHT [Re: Cab_Burge] #2897333
03/09/21 10:48 AM
03/09/21 10:48 AM
A727Tflite Offline
A727Tflite  Offline
Never again tsk
Cab, where did you find the spec. of 1/8” using a 15” dimension?
Re: CHECKING REAR FOR STRAIGHT [Re: A727Tflite] #2897413
03/09/21 03:46 PM
03/09/21 03:46 PM
Roundy round racers years ago shruggy
Re: CHECKING REAR FOR STRAIGHT [Re: AndyF] #2897466
03/09/21 07:08 PM
03/09/21 07:08 PM
E
ek3 Offline
ek3  Offline
E
exactly .... i have a jig made just for this. you chain the rear down over the rims and roll it over 1 time . we use a jack to re-square them. rims must be true..... i used this on circle track rears for years. we got bumped all the time and it was the fastest sure fire way to check and repair them all at 1 time.... sliding the axels out will let you know if its bad enough too ..
