Re: CHECKING REAR FOR STRAIGHT
[Re: A/MP]
#2896806
03/07/21 04:06 PM
03/07/21 04:06 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
I use two carpenter squares and a tape measure , have some one hold one of the squares against the axle flange, no brake drum or rotor on the axles and measure out around 15 inches from the center of the axles on both sides to the front side and see what you get, then do the same towards the rear and then if you can straight up and down. The stock wheel tubs limit how far you can measure straight up, what ever you can get use the same length measuring straight down I like to see less than 1/8 inch variance front to back with the front being narrower for toe in, no variance straight up compared to straight down Please let us know what you do no mater what method you choose
[Re: Cab_Burge]
#2896814
03/07/21 04:32 PM
03/07/21 04:32 PM
Posts: 11,607 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Unbolt the axles, slide them in and out. Check for square, having to pull them one way or the other (likely back if its bent) to get them to slide in, and going in and out smoothly.
I've seen some hacked up narrow jobs with the ends on stupid crooked and the axles wouldn't even go in all the way.
[Re: CMcAllister]
#2897127
03/08/21 02:37 PM
03/08/21 02:37 PM
Posts: 4,684 On the parachute mount
n20mstr
I've seen some hacked up narrow jobs with the ends on stupid crooked and the axles wouldn't even go in all the way. THIS ^^^
....BAD A$$ STREET CAR.....
[Re: A/MP]
#2897199
03/08/21 07:12 PM
03/08/21 07:12 PM
Cab_Burge
Being a cabinet maker, I thought about a straight edge on each flange and measure the diagonals for and aft of the housing in general. That work? Absolutely I measured off the ends of the squares instead of across and over the housing, I like and use the KISS principles
[Re: Cab_Burge]
#2897225
03/08/21 09:05 PM
03/08/21 09:05 PM
Posts: 3,083 Michigan
A727Tflite
Great idea but worthless info until you have a specification to go against.
Use a 4’ long straight edge and it has 1/8” toe in versus a 1’ long straight edge and it has 1/8” in toe in. That’s two different values in degrees of toe.
What’s the spec?
Now if you get zero in each case - you may be on to something. And that is assuming the ends were welded on square to the tubes.
In the OPs case, I would go with McAllister’s suggestion. Starting from scratch - use an arbor and pucks.
[Re: Cab_Burge]
#2897316
03/09/21 09:14 AM
03/09/21 09:14 AM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
The simplest and quickest way I have used for preliminary checking for straight is put a set of tires or even just rims on, while it is sitting on floor, rotate the housing around and you will see wheels move in and out as it is rotated. I have seen supposedly STRAIGHT housings that were done with the solid bar narrowing kits when welding still show quite a bit of wheels moving in and out as housing is rotated. Again, quick and simple, but definitely lets you know how straight..... or not!
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
[Re: AndyF]
#2897466
03/09/21 07:08 PM
03/09/21 07:08 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
Depends what you mean by straight. Also depends on what tools you have or are willing to buy. exactly .... i have a jig made just for this. you chain the rear down over the rims and roll it over 1 time . we use a jack to re-square them. rims must be true..... i used this on circle track rears for years. we got bumped all the time and it was the fastest sure fire way to check and repair them all at 1 time.... sliding the axels out will let you know if its bad enough too ..
