W600? #2895886
03/04/21 11:29 PM
03/04/21 11:29 PM
New Brunswick, Canada
TrxR Offline OP
TrxR  Offline OP
Seen a 75 W600 the other day and was wondering if anyone could tell me what they used for transmission /transfer case and front and rear housings ?
Re: W600? [Re: TrxR] #2896684
03/07/21 09:07 AM
03/07/21 09:07 AM
Guitar Jones Offline
The only manufacturer that I know of that sells an AWD from the factory is IH, the others are all conversions most likely done by Marmon-Herrington. This maybe what you saw but I could be wrong.
Re: W600? [Re: Guitar Jones] #2896798
03/07/21 03:36 PM
03/07/21 03:36 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Nowhere does it say AWD. The W600 and the previous W500 were part time 4 wheel drive.
A 75 would have used Rockwell FDS75 (6.80:1) or Dana 70 axles (6.20:1). The transmissions were NP435 or NP540. Transfer case was a Rockwell T223
Seeing that you are in Canada, they may have used a NP201 transfer case on Canadian trucks.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: W600? [Re: Soopernaut] #2896848
03/07/21 07:30 PM
03/07/21 07:30 PM
They say AWD because many of them have tandem rear axles. They are not full time AWD units. But like I said, I could be wrong, I don't know much about the older heavy trucks.
Re: W600? [Re: Guitar Jones] #2896941
03/07/21 11:53 PM
03/07/21 11:53 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Marmon Herrington.....there's a skeleton from the past! The power company I work for bought some Ford F450 service buckets with Marmon Herrington 4WD conversions. The transfer cases looked like something out of a Toyota Tacoma, and would last about 6 months. January of 1998, we were headed to Watertown, NY to help get the power back on after a monster ice storm....and the transfer case came out of that POS Ford in Scranton, PA. I limped it into a Ford dealership in downtown Scranton. You should have seen the look on the poor old mechanics faces when they looked under the truck! Took em 2 weeks to fix it, and I thought they did good at that!
Re: W600? [Re: Soopernaut] #2898308
03/11/21 10:58 PM
03/11/21 10:58 PM
TrxR Offline OP
TrxR  Offline OP
Thanks everyone. This was an american truck. I didn't get a good look to even see what engine was in it. I thought it looked like it would be a good candidate for a Cummins swap.
Re: W600? [Re: JDMopar] #2898327
03/12/21 01:15 AM
03/12/21 01:15 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
The gov't had a bunch of M-H 4wd stuff. Pain in the ass for getting parts
Re: W600? [Re: A990] #2901022
03/20/21 11:07 AM
03/20/21 11:07 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Rockwell T223
Kevin
