Re: W600?
[Re: TrxR]
#2896684
03/07/21 09:07 AM
03/07/21 09:07 AM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
The only manufacturer that I know of that sells an AWD from the factory is IH, the others are all conversions most likely done by Marmon-Herrington. This maybe what you saw but I could be wrong.
Re: W600?
[Re: Guitar Jones]
#2896798
03/07/21 03:36 PM
03/07/21 03:36 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Nowhere does it say AWD. The W600 and the previous W500 were part time 4 wheel drive.
A 75 would have used Rockwell FDS75 (6.80:1) or Dana 70 axles (6.20:1). The transmissions were NP435 or NP540. Transfer case was a Rockwell T223
Seeing that you are in Canada, they may have used a NP201 transfer case on Canadian trucks.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: W600?
[Re: Soopernaut]
#2896848
03/07/21 07:30 PM
03/07/21 07:30 PM
Guitar Jones
They say AWD because many of them have tandem rear axles. They are not full time AWD units. But like I said, I could be wrong, I don't know much about the older heavy trucks.
Re: W600?
[Re: Guitar Jones]
#2896941
03/07/21 11:53 PM
03/07/21 11:53 PM
Posts: 8,498 Candler,NC / Myrtle Beach, SC
JDMopar
The only manufacturer that I know of that sells an AWD from the factory is IH, the others are all conversions most likely done by Marmon-Herrington. This maybe what you saw but I could be wrong. Marmon Herrington.....there's a skeleton from the past! The power company I work for bought some Ford F450 service buckets with Marmon Herrington 4WD conversions. The transfer cases looked like something out of a Toyota Tacoma, and would last about 6 months. January of 1998, we were headed to Watertown, NY to help get the power back on after a monster ice storm....and the transfer case came out of that POS Ford in Scranton, PA. I limped it into a Ford dealership in downtown Scranton. You should have seen the look on the poor old mechanics faces when they looked under the truck! Took em 2 weeks to fix it, and I thought they did good at that!
