Re: Indy 2-plane intakes
[Re: hemienvy]
#2893777
02/27/21 04:07 PM
02/27/21 04:07 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
There is only one casting...... fits RB only.
It has MW sized runners that are reduced down to std port size at the flange.
For a low deck there is the 400-2/-3 or the Mod Man, or the TR
[Re: fast68plymouth]
#2894647
03/02/21 03:53 AM
03/02/21 03:53 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
For a low deck there is the 400-2/-3 or the Mod Man, or the TR That is right as you did that to mine of opening the flange Dwayne and you did a great job. I run that intake on my street car that gets raced now and then and I do like the intake. Ron
[Re: hemienvy]
#2894778
03/02/21 12:39 PM
03/02/21 12:39 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Ron and I have similar builds but my EZ's still have the stock size port window. Ron's heads are opened up to MW ports. I have been running the Performer RPM and I have been 10.91 @ 124 MPH with mine. I think the big ports and that Indy intake make his car faster than mine. I have a Victor and a new annular 1050 that I'm gonna throw on this summer and try to get to the track and see what it does. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2895032
03/02/21 10:33 PM
03/02/21 10:33 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I feel the Indy dual plane is a very good dual plane. I have it in the standard port form (just port matched to stealth heads). It’s on a pump gas 505 RB and made good power on the dyno and ran pretty good at the track. I just lowered the plenum center divider and radiused the upper transition. It made 600+ hp on dyno and ran 11.55 at 4200+ lbs. i’m very happy with it’s performance.
