Re: Cam choice question
[Re: FASTBACK66]
#289374
04/16/09 11:48 AM
04/16/09 11:48 AM
RapidRobert
Hi vinny. people have had problems with the 750 eddy.
[Re: RapidRobert]
#289375
04/16/09 12:17 PM
04/16/09 12:17 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
a 650 eddie thunder series AVS or 600 eddie AFB might actually be a better carb for street manners/economy/0-5000 RPM performance. on my 360, I had MUCH better low RPM/off idle responsiveness with a 600 eddie over the 750..felt like I gained 20+ HP down around the converter flash point (~2500 RPM) and didn't lose anything up top by the butt dyno....also gained 2mpg.
[Re: FASTBACK66]
#289378
04/17/09 08:48 AM
04/17/09 08:48 AM
patrick
Grand Haven, MI
Thanks for the advice. Guess I will use a smaller carb. I have a 600 Eddie and a 625 (I think) Carter. With the MSD ignition I guess I wasn't worried about overfueling but overlooked bottom end performance.Comp. XE262 it is. Any suggestions for converter?
Thanks again, Vinny
FWIW, my 360 is about 7.8:1 acutal measured (reringed longblock) with a comp XE262, and it moves my 3950 lb boat very well, keeps up with a LX hemi car from a roll, which should translate into 14's at the strip. I'm running a MP166k converter, 27" tires, 3.55 rear with an A500 OD tranny.
[Re: patrick]
#289379
04/17/09 09:07 AM
04/17/09 09:07 AM
Summit has the "big " Summit brand cam and lifter kit on sale less than $100 and for a low compression 383 it would do a great job cheap--it really is a great street cam
