Post deleted by Defbob
[Re: Dyno1]
#289144
04/15/09 02:02 PM
04/15/09 02:02 PM
Re: Best Mini Starter?
[Re: Irun5snd8th]
#289148
04/15/09 02:38 PM
04/15/09 02:38 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
I can honestly say, the RobbMC starter is hands down, the best mini-starter I have ever owned. You bolt it up, and can actually spin the assembly, and adjustwhere you want to have the terminals. It was the only starter I couold find without having to beat-uo the headers on my 71 Plymouth 4 speed, with an 11 inch flywheel and TTI headers. I promise you reat customer support and a superbly engineered starter.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#289149
04/15/09 02:43 PM
04/15/09 02:43 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I have had very good luck with powermaster starter. The mopar mini starter hit the oil galley on my KB block.
[Re: MoparforLife]
#289151
04/15/09 05:14 PM
04/15/09 05:14 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
What compression is that hemi.I have 12.5 in the 440 and my mini spins it like a /6.My kid has the Source mini in his hipo 413 and it does the same.Unless you are 14 or 15 to one something is wrong.Rocky
Chrysler Firepower
#289154
04/15/09 05:50 PM
04/15/09 05:50 PM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
been using factory starters for years no problems
, i use one from a 90 dodge ram, its a mini and it works perfect in my cuda
[Re: Dyno1]
#289158
04/15/09 10:17 PM
04/15/09 10:17 PM
The only starter i will ever usea gain is the MEZIERE TS104 starter, cranks like no order starter i have ever used, and im at 14.8 compression. powermaster didnt sit right in my megablock. i couldnt get it to line up and i turned it in all different directions with adjustable positions.
