Re: Data Loggers -Innovative Motorsports
[Re: GTSocker]
#2890136
02/18/21 04:00 PM
02/18/21 04:00 PM
Posts: 117 Aus
hysteric
Aus
I got all my innovate gear from Greg Kelley which included a driveshaft collar at MotorsportsInnovationsSpeed SensorsHe no longer sells the Innovate gear but I'm sure he should be able to help you out.
[Re: GTSocker]
#2890320
02/18/21 11:59 PM
02/18/21 11:59 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I could never get their LMA-3 AuxBox to work. None of the 5 channels could ever read-off any values, despite the fact that the RPM/Tach signal was easily handled by the much less sophisticated LMA-2 RPM Converter. Go figure...and yeah, I spend time playing around with the different -ve and GROUND signals, making sure they were noise free, etc, etc.
[Re: dvw]
#2891705
02/21/21 11:03 PM
02/21/21 11:03 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
Should not be in a NSS car anyway
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: DoubleD]
#2891796
02/22/21 10:35 AM
02/22/21 10:35 AM
Posts: 9,842 MI, usa
dvw
MI, usa
I run plenty of other stuff besides N/SS. Hell the last time out I foot braked 4 rds in Super Pro/Top. The logger is completely removable. My car has been checked at NMCA more than once. Doug
[Re: 66coronet]
#2892099
02/23/21 06:19 AM
02/23/21 06:19 AM
dvw
MI, usa
Agreed. The reason we built this thing in the first place was to sort the car. Once its done. Its set and forget unless a different combo is tried. We regularly run against cars with starting line chips, trans brakes, air shifters and Racepac. Doug
[Re: 66coronet]
#2892115
02/23/21 08:48 AM
02/23/21 08:48 AM
Posts: 10,027 MN
JERICOGTX
MN
If you are running heads up, get every ounce out of the car type events, I am all for the sensors and data they can provide. If you are bracket or index racing I do not think they should ever be in the car. All you need them for is one good weekend of data gathering and then use the data with todays ignitions to make or write the "perfect map" or timing curve to achieve the perfect run over and over. Is it a full proof science? No. I believe it is a hell of a lot better than reading weather from day to day, tuning and dialing or setting up for your index without it. To each his own I guess. I just dont agree with the sensors ever touching a car that is in a bracket type event. Yeah, I'm going to spend over a $1000 for a data logging setup, then only use it once... LOL. Doug, don't you know if you enter a NSS race once, you can never race another class again?
69 GTX
68 Road Runner
[Re: Whompin_Wedge]
#2892313
02/23/21 03:20 PM
02/23/21 03:20 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
All I am going to say is as long as MSD Grids are allowed in NSS what does it matter.
Thanks, Casey FJ Plenty of logging capability in a Grid. I know everyone thinks they are a great way to "cheat" but if laying dots is cheating then you can use plenty of other things besides a grid to do that. Most the EFI controllers out there will data log and can be made to ride dots and repeat as well. The only way around it is gonna be a mandatory rule for something like a 6 or 7al box with no piggy back boxes or any logging data. NHRA actually just amended the rulebook to include things like laptops and ignition/efi tunes to be a random teched item for all classes. It no doubt is happening by racers lots of ways to "hide" programming in the software of any digital style controller. IMO if I am data logging I prefer racepak stuff. Simple to use and pretty reliable as well. Where they are legal. If a grid is allowed then I see ZERO reason to not allow a racepak
[Re: Al_Alguire]
#2892373
02/23/21 05:20 PM
02/23/21 05:20 PM
Posts: 679 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
Thanks, Casey FJ Plenty of logging capability in a Grid. I know everyone thinks they are a great way to "cheat" but if laying dots is cheating then you can use plenty of other things besides a grid to do that. Most the EFI controllers out there will data log and can be made to ride dots and repeat as well. The only way around it is gonna be a mandatory rule for something like a 6 or 7al box with no piggy back boxes or any logging data. NHRA actually just amended the rulebook to include things like laptops and ignition/efi tunes to be a random teched item for all classes. It no doubt is happening by racers lots of ways to "hide" programming in the software of any digital style controller. IMO if I am data logging I prefer racepak stuff. Simple to use and pretty reliable as well. Where they are legal. If a grid is allowed then I see ZERO reason to not allow a racepak Yea Al, that is what I am saying... The Grid is legal, but a stand alone data logger is not within NSS rules. Makes no sense. Casey FJ
[Re: JERICOGTX]
#2892380
02/23/21 05:43 PM
02/23/21 05:43 PM
Posts: 4,682 On the parachute mount
n20mstr
If you are running heads up, get every ounce out of the car type events, I am all for the sensors and data they can provide. If you are bracket or index racing I do not think they should ever be in the car. All you need them for is one good weekend of data gathering and then use the data with todays ignitions to make or write the "perfect map" or timing curve to achieve the perfect run over and over. Is it a full proof science? No. I believe it is a hell of a lot better than reading weather from day to day, tuning and dialing or setting up for your index without it. To each his own I guess. I just dont agree with the sensors ever touching a car that is in a bracket type event. Yeah, I'm going to spend over a $1000 for a data logging setup, then only use it once... LOL. Doug, don't you know if you enter a NSS race once, you can never race another class again? Why so dead set against data logging?? A Racepak sportsman is under 1000.00 and once you have one, you wonder how you ever raced without it. Yes im a heads up type racer, but i see plenty of 10.00 and 8.50 guys repeating and i mean 8.500 with data loggers. Or is that your point? amkes it too easy for bracket racers to dial in a car. Whatever the case, you see so much useful info that you would never learn otherwise..
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2892558
02/24/21 07:12 AM
02/24/21 07:12 AM
Posts: 10,027 MN
JERICOGTX
MN
If you are running heads up, get every ounce out of the car type events, I am all for the sensors and data they can provide. If you are bracket or index racing I do not think they should ever be in the car. All you need them for is one good weekend of data gathering and then use the data with todays ignitions to make or write the "perfect map" or timing curve to achieve the perfect run over and over. Is it a full proof science? No. I believe it is a hell of a lot better than reading weather from day to day, tuning and dialing or setting up for your index without it. To each his own I guess. I just dont agree with the sensors ever touching a car that is in a bracket type event. Yeah, I'm going to spend over a $1000 for a data logging setup, then only use it once... LOL. Doug, don't you know if you enter a NSS race once, you can never race another class again? Why so dead set against data logging?? A Racepak sportsman is under 1000.00 and once you have one, you wonder how you ever raced without it. Yes im a heads up type racer, but i see plenty of 10.00 and 8.50 guys repeating and i mean 8.500 with data loggers. Or is that your point? amkes it too easy for bracket racers to dial in a car. Whatever the case, you see so much useful info that you would never learn otherwise.. I'm not deadest against data loggers. In fact, I have a RacePak in my car. Not sure why some classes are against them, when the rules say no delay boxes, or trans brakes. If it's just doing the basic stuff, what's the big deal? I have one to monitor clutch slippage. I know one series of racing that will not allow the racers to enter multiple classes, because it gives them an "unfair" advantage.
69 GTX
68 Road Runner
