511 with TrickFlow 270s and CNC Xram #2889589
02/17/21 11:50 AM
02/17/21 11:50 AM
NY
B1duster Offline OP
B1duster  Offline OP
NY
Re: 511 with TrickFlow 270s and CNC Xram [Re: B1duster] #2889622
02/17/21 01:40 PM
02/17/21 01:40 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Impressive numbers for sure, especially with the crossram. My engine's always seem to be down on torque compared to other builds I read about, and my 493 w Indy-1 and similar compression and roller is down almost 100lb/ft compared to this one! Maybe thats my crappy engine or engine shops dyno.
2 kids and a dog
Re: 511 with TrickFlow 270s and CNC Xram [Re: TonyS451] #2889631
02/17/21 02:02 PM
02/17/21 02:02 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My 512/400 made 809hp at that compression....with Indy EZ1 heads and a single plane Indy intake. That little beast went 6.0 in my car.
Re: 511 with TrickFlow 270s and CNC Xram [Re: Dragula] #2889640
02/17/21 02:37 PM
02/17/21 02:37 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
How in the world does that car weigh over 3500 lbs??
Re: 511 with TrickFlow 270s and CNC Xram [Re: GTS340] #2889671
02/17/21 03:38 PM
02/17/21 03:38 PM
Dragula Offline
Dragula  Offline
It doesn't...Its 3k with me in it.
Re: 511 with TrickFlow 270s and CNC Xram [Re: TonyS451] #2889679
02/17/21 04:02 PM
02/17/21 04:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Tony, I suspect if the two motors were tested back to back on the same dyno, the tq discrepancy would be less.
The pic of the motor in the article shows it with 1-7/8x3” headers(look like Hooker Competition) which is going to impact both ends of the curve(compared to what most people would use in the race car for a build like that).
The fairly low peak rpm point for HP, along with it making more TQ than HP, indicates it’s running out of “something”.
That amount of tq(738) out of 511”(1.44/ci)would be abnormally good on the dyno here for that type of build.
(The equivalent of 642ft/lbs from a 446)
Re: 511 with TrickFlow 270s and CNC Xram [Re: Dragula] #2890182
02/18/21 05:27 PM
02/18/21 05:27 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
6.00 at 114.5 mph in a 3000 lb vehicle is somewhere between 685-700 horsepower.
