MM 305 lobe #2887596
02/13/21 12:44 PM
02/13/21 12:44 PM
PA
Harry's Taxi 2 Offline OP
PA
Has anyone here use a Comp cams MM305 intake lobe with a 1.6 ratio rocker? If so, what spring pressure and rpm did you run it to?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: MM 305 lobe [Re: Harry's Taxi 2] #2889277
02/16/21 04:14 PM
02/16/21 04:14 PM
UK
U
UKDART Offline
UKDART  Offline
U
UK
I have this cam with 1.6 on the inlet using PAC -1916 springs. Shift at 6700 rpm, crosses line 7000-7100.
Love this cam 8.82@151 in my '67 Dart, 512 RB 14-1 comp cnc'd 440-1s Pro Systems methanol SV1.
Re: MM 305 lobe [Re: UKDART] #2889295
02/16/21 04:44 PM
02/16/21 04:44 PM
PA
PA
Thanks for the reply. I thought maybe a 1.6 rocker might make an already aggressive lobe a little too much so that's why I was asking for some real world info.
Re: MM 305 lobe [Re: Harry's Taxi 2] #2889333
02/16/21 06:42 PM
02/16/21 06:42 PM
New York, USA
Chargerfan68 Offline
New York, USA
Just curious what the difference between the MM lobes and the XX lobes? I read the catalog descriptions, but looking for more detailed information. Design and actual intended useage difference as well as difference in spring requirements and maintenance. When i saw this post, i immediately thought i run this lobe family in my rb 505, but when i went to confirm, i saw it is the XX lobes. So curious about that info.
Re: MM 305 lobe [Re: UKDART] #2889346
02/16/21 07:12 PM
02/16/21 07:12 PM
NC
440Jim Offline
440Jim  Offline
NC
I ran that cam for years, with 1.5 rockers. Great flat tappet IMO.
150 lbs seat, 440 open is about right. That is a lot of pressure, so I used edm oiling lifters.
0.650"/0.630" MM305S
Re: MM 305 lobe [Re: Chargerfan68] #2889511
02/17/21 07:11 AM
02/17/21 07:11 AM
PA
PA
If you're asking me about the lobe differences, I'm probably not the one to ask. It does appear the intake lobe is an MM and the exhaust is an XX lobe.
I measured the cam and it is what it's supposed to be. (that's been a problem for me with some other brands lately)
Re: MM 305 lobe [Re: 440Jim] #2889512
02/17/21 07:20 AM
02/17/21 07:20 AM
PA
PA
Thanks for responding, I think i'll run the 1.5's initially.
I'm now running around that same spring pressures on a previous cam with tool steel lifters and the wear (or rather the lack of it) appears pretty good.
Re: MM 305 lobe [Re: UKDART] #2889516
02/17/21 08:15 AM
02/17/21 08:15 AM
UK
rb446 Offline
rb446  Offline
UK
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
