Trailer Q: 5th wheel to Goose #2888124
02/14/21 01:31 PM
02/14/21 01:31 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Can a 5th wheel trailer be converted to a goose neck trailer easily?
Re: Trailer Q: 5th wheel to Goose [Re: Dragula] #2888161
02/14/21 02:06 PM
02/14/21 02:06 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
There are adapters, however I use the B&W system on my trucks, The gooseneck mount is attached to the frame and a fifth-wheel adapter is used. I have used it for years with a 44' fifth wheel enclosed trailer with no issues, mounts and removes in seconds...https://www.bwtrailerhitches.com/5th-wheel-hitch
JB Rhinehart, Realist
A-Body's RULE!
Re: Trailer Q: 5th wheel to Goose [Re: Rhinodart] #2888175
02/14/21 02:21 PM
02/14/21 02:21 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Yes they can be converted. You just unbolt your pin box and bolt on the adapter kit. Kit
Re: Trailer Q: 5th wheel to Goose [Re: NITROUSN] #2888322
02/14/21 07:04 PM
02/14/21 07:04 PM
Dragula Offline OP
Dragula  Offline OP
That's interesting....Found a trailer I like, but its a 5th wheel and I am setup for GN
Re: Trailer Q: 5th wheel to Goose [Re: Dragula] #2888365
02/14/21 07:44 PM
02/14/21 07:44 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
What brand is the trailer?...don't see many car trailers with fifth wheel hitches...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Trailer Q: 5th wheel to Goose [Re: W.I.N. Racing] #2888378
02/14/21 07:59 PM
02/14/21 07:59 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My old Haulmark fiver at Frisco, Colorado after blowing the hose off the turbo on the 99 dually...LOL I only went through 7 NV4500's in this truck... frown
A-Body's RULE!
Re: Trailer Q: 5th wheel to Goose [Re: Dragula] #2888396
02/14/21 08:46 PM
02/14/21 08:46 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The one I linked to goes over your fifth wheel pin. Here are some others. More adapters
Re: Trailer Q: 5th wheel to Goose [Re: NITROUSN] #2888469
02/14/21 10:56 PM
02/14/21 10:56 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
One more thing about a fifth wheel. NEVER GET IN A HURRY HOOKING IT UP! Leave the landing gear on the trailer down after you think it is hooked up then pull forward a short amount to make sure that the pin is set, just like you would do on a semi. It will save the sides of your truck box, DAMHIK!
A-Body's RULE!
Re: Trailer Q: 5th wheel to Goose [Re: Dragula] #2888482
02/15/21 12:06 AM
02/15/21 12:06 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Personally, I would never use an adapter on a heavy trailer. The adapter acts like a lever, and will flex the trailer frame where it Z's up to the 5th wheel pin area. The frame will eventually crack and break on a heavy trailer. Use a B&W Turnover Ball hitch under the truck bed, and a B&W Companion Hitch in the bed to tow the 5th wheel. The companion attaches to the Turnover Ball hitch, and there are no rails in your truck bed to be in the way when you aren't using the 5th wheel Companion Hitch. twocents
Re: Trailer Q: 5th wheel to Goose [Re: JDMopar] #2888485
02/15/21 12:08 AM
02/15/21 12:08 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
That's what I'd do. I converted a goose neck trailer to fifth wheel, first thing I noticed after conversion was a noticeably better ride.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Trailer Q: 5th wheel to Goose [Re: 3hundred] #2888622
02/15/21 11:41 AM
02/15/21 11:41 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
As I said above, the B&W hitch with the Companion is the only way to go! Pricey but you will never need another. I made the mistake of selling the unit with my dually, should have kept it... whiney
A-Body's RULE!
Re: Trailer Q: 5th wheel to Goose [Re: Rhinodart] #2888662
02/15/21 12:26 PM
02/15/21 12:26 PM
N
NITROUSN Offline
NITROUSN  Offline
N
As far as converting from 5th wheel to goose neck it can be done. I know of several and have never seen failures. It is like anything else do it right and inspect often. Other things to consider is how much towing will you be doing. If it was to make a living then buy the right trailer. If it is for recreation just do it. I believe most failures could be attributed to extreme conditions, over loading, poor quality trailer, lack of maintenance. A lot of cracks come from cycling, and harmonic vibrations. If they were unsafe they would be banned from selling. B and W does make nice hitches. That companion is one heavy SOB to take in and out. If you do not care about taking the hitch out then look around for one. Most of the used ones can be had for 5 to 7 hundred bucks. There is some set up required when first installing one. Each will vary depending on your bed floor.
Re: Trailer Q: 5th wheel to Goose [Re: NITROUSN] #2888705
02/15/21 01:27 PM
02/15/21 01:27 PM
Byron, NY
Byron, NY
Admittedly I have never pulled a Fifth wheel trailer (only goosenecks) but it seems like they are less forgiving than a Goose neck especially on uneven terrain. Without having done any investigations, what are the advantages of a fifth vs a goose?
'60 Willys CJ5
Re: Trailer Q: 5th wheel to Goose [Re: W.I.N. Racing] #2888725
02/15/21 01:46 PM
02/15/21 01:46 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
All I know of, better ride, no safety chains required, less landing gear cranking. Only downside is what Jim mentioned, if you don't latch the jaws (should be automatic) you can drive out from under it. When I had my Freightliner I always double checked the latch before leaving the truck stop in case some clown might have pulled the release, never happened to me, but heard stories.
'69 300 Convertible
'16 300 S Hemi
Re: Trailer Q: 5th wheel to Goose [Re: 3hundred] #2888763
02/15/21 02:49 PM
02/15/21 02:49 PM
Dragula Offline OP
Dragula  Offline OP
So its a Toy Hauler trailer, and it would be seeing some interesting locations with uneven ground.
So I didn't want all the 5th wheel crap in the bed, when my truck was setup for a goose. And mines a short bed, not a long bed which really scares me.
And second, it seems like a real pain and I should just go tag...
Re: Trailer Q: 5th wheel to Goose [Re: Dragula] #2888899
02/15/21 07:38 PM
02/15/21 07:38 PM
Byron, NY
Byron, NY
Use a goose neck you'll never want a tag again...in the spring come drag my 36' around the block you'll see what I mean.
'60 Willys CJ5
Re: Trailer Q: 5th wheel to Goose [Re: W.I.N. Racing] #2888949
02/15/21 09:49 PM
02/15/21 09:49 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I use a tag because I need the bed, goose or fifth takes most of it away, plus I like to run a cap. This 36' Imperial I had was the cats [censored], wish I would have never sold it!
A-Body's RULE!
Re: Trailer Q: 5th wheel to Goose [Re: Dragula] #2889391
02/16/21 08:34 PM
02/16/21 08:34 PM
JDMopar Offline
JDMopar  Offline
My 2004 Dodge is a quad cab 4WD.....and a short bed. The 5th wheel camper we had for several years was a Sunnybrook, and the dry weight was 12K lbs! It pulled it just fine, and I was always careful to not jack it too far around while backing or turning it. If your goose neck hitch is one where you have to pull a little lever in the drivers side rear wheel well to flip the ball over, it is more than likely a B&W hitch. All you have to do is pull the ball out, and drop the solid steel square bar from the Companion hitch down into the hole the gooseneck ball just came out of. The Companion hitch sits in the bed on top of that square steel bar. You torque the bolt going into the top of the square bar to 40 ft lbs, and the u bolts going around the square bar to 80 ft lbs....and it's ready to tow. No rails in the bed....no more holes in the bed.
Re: Trailer Q: 5th wheel to Goose [Re: Dragula] #2890272
02/18/21 09:29 PM
02/18/21 09:29 PM
USA
blackorwhite Offline
USA
Yup! you just need a new hitch for that!
Re: Trailer Q: 5th wheel to Goose [Re: Dragula] #2890347
02/19/21 04:21 AM
02/19/21 04:21 AM
I had a 34 ft. fifth wheel camping trailer that weighed 11,500 on the two axles and added around 700 lbs. on the rear axle and 350 lbs. onto the front axle of my 2006 Ram 3500 4x4 long bed, that trailer hooked up made my truck feel and ride a bunch better than my 24 Ft Pace Shadow did weighing 8600 Lbs. on the two axles adding 500 Lbs. onto the rear axle and lighting the front axle around 150 Lbs. shruggy
I've never towed a goose neck but I really like towing that travel trailer a lot better than any of the three enclosed car trailers I've owned and towed twocents
