Re: Trailer Q: 5th wheel to Goose
[Re: Dragula]
#2888161
02/14/21 02:06 PM
02/14/21 02:06 PM
Posts: 43,555 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Can a 5th wheel trailer be converted to a goose neck trailer easily? There are adapters, however I use the B&W system on my trucks, The gooseneck mount is attached to the frame and a fifth-wheel adapter is used. I have used it for years with a 44' fifth wheel enclosed trailer with no issues, mounts and removes in seconds...https://www.bwtrailerhitches.com/5th-wheel-hitch
JB Rhinehart, Realist
A-Body's RULE!
[Re: NITROUSN]
#2888322
02/14/21 07:04 PM
02/14/21 07:04 PM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
Yes they can be converted. You just unbolt your pin box and bolt on the adapter kit. Kit That's interesting....Found a trailer I like, but its a 5th wheel and I am setup for GN
[Re: Dragula]
#2888365
02/14/21 07:44 PM
02/14/21 07:44 PM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
What brand is the trailer?...don't see many car trailers with fifth wheel hitches...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2888378
02/14/21 07:59 PM
02/14/21 07:59 PM
Rhinodart
Rhinotruck
Rhinotruck
My old Haulmark fiver at Frisco, Colorado after blowing the hose off the turbo on the 99 dually...LOL I only went through 7 NV4500's in this truck...
A-Body's RULE!
[Re: NITROUSN]
#2888469
02/14/21 10:56 PM
02/14/21 10:56 PM
Rhinodart
Rhinotruck
Rhinotruck
One more thing about a fifth wheel. NEVER GET IN A HURRY HOOKING IT UP! Leave the landing gear on the trailer down after you think it is hooked up then pull forward a short amount to make sure that the pin is set, just like you would do on a semi. It will save the sides of your truck box, DAMHIK!
A-Body's RULE!
[Re: Dragula]
#2888482
02/15/21 12:06 AM
02/15/21 12:06 AM
Posts: 8,489 Candler,NC / Myrtle Beach, SC
JDMopar
Personally, I would never use an adapter on a heavy trailer. The adapter acts like a lever, and will flex the trailer frame where it Z's up to the 5th wheel pin area. The frame will eventually crack and break on a heavy trailer. Use a B&W Turnover Ball hitch under the truck bed, and a B&W Companion Hitch in the bed to tow the 5th wheel. The companion attaches to the Turnover Ball hitch, and there are no rails in your truck bed to be in the way when you aren't using the 5th wheel Companion Hitch.
[Re: JDMopar]
#2888485
02/15/21 12:08 AM
02/15/21 12:08 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Personally, I would never use an adapter on a heavy trailer. The adapter acts like a lever, and will flex the trailer frame where it Z's up to the 5th wheel pin area. The frame will eventually crack and break on a heavy trailer. Use a B&W Turnover Ball hitch under the truck bed, and a B&W Companion Hitch in the bed to tow the 5th wheel. The companion attaches to the Turnover Ball hitch, and there are no rails in your truck bed to be in the way when you aren't using the 5th wheel Companion Hitch. That's what I'd do. I converted a goose neck trailer to fifth wheel, first thing I noticed after conversion was a noticeably better ride.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Rhinodart]
#2888662
02/15/21 12:26 PM
02/15/21 12:26 PM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
As far as converting from 5th wheel to goose neck it can be done. I know of several and have never seen failures. It is like anything else do it right and inspect often. Other things to consider is how much towing will you be doing. If it was to make a living then buy the right trailer. If it is for recreation just do it. I believe most failures could be attributed to extreme conditions, over loading, poor quality trailer, lack of maintenance. A lot of cracks come from cycling, and harmonic vibrations. If they were unsafe they would be banned from selling. B and W does make nice hitches. That companion is one heavy SOB to take in and out. If you do not care about taking the hitch out then look around for one. Most of the used ones can be had for 5 to 7 hundred bucks. There is some set up required when first installing one. Each will vary depending on your bed floor.
[Re: NITROUSN]
#2888705
02/15/21 01:27 PM
02/15/21 01:27 PM
W.I.N. Racing
Byron, NY
Admittedly I have never pulled a Fifth wheel trailer (only goosenecks) but it seems like they are less forgiving than a Goose neck especially on uneven terrain. Without having done any investigations, what are the advantages of a fifth vs a goose?
[Re: W.I.N. Racing]
#2888725
02/15/21 01:46 PM
02/15/21 01:46 PM
3hundred
Colleyville
Admittedly I have never pulled a Fifth wheel trailer (only goosenecks) but it seems like they are less forgiving than a Goose neck especially on uneven terrain. Without having done any investigations, what are the advantages of a fifth vs a goose? All I know of, better ride, no safety chains required, less landing gear cranking. Only downside is what Jim mentioned, if you don't latch the jaws (should be automatic) you can drive out from under it. When I had my Freightliner I always double checked the latch before leaving the truck stop in case some clown might have pulled the release, never happened to me, but heard stories.
[Re: Dragula]
#2888899
02/15/21 07:38 PM
02/15/21 07:38 PM
W.I.N. Racing
Byron, NY
Use a goose neck you'll never want a tag again...in the spring come drag my 36' around the block you'll see what I mean.
[Re: W.I.N. Racing]
#2888949
02/15/21 09:49 PM
02/15/21 09:49 PM
Rhinodart
Rhinotruck
Rhinotruck
I use a tag because I need the bed, goose or fifth takes most of it away, plus I like to run a cap. This 36' Imperial I had was the cats [censored], wish I would have never sold it!
A-Body's RULE!
[Re: Dragula]
#2889391
02/16/21 08:34 PM
02/16/21 08:34 PM
JDMopar
My 2004 Dodge is a quad cab 4WD.....and a short bed. The 5th wheel camper we had for several years was a Sunnybrook, and the dry weight was 12K lbs! It pulled it just fine, and I was always careful to not jack it too far around while backing or turning it. If your goose neck hitch is one where you have to pull a little lever in the drivers side rear wheel well to flip the ball over, it is more than likely a B&W hitch. All you have to do is pull the ball out, and drop the solid steel square bar from the Companion hitch down into the hole the gooseneck ball just came out of. The Companion hitch sits in the bed on top of that square steel bar. You torque the bolt going into the top of the square bar to 40 ft lbs, and the u bolts going around the square bar to 80 ft lbs....and it's ready to tow. No rails in the bed....no more holes in the bed.
