70 r.r. voltage regulator #2888007
02/14/21 10:46 AM
02/14/21 10:46 AM
tampa florida
1badrt Offline OP
1badrt  Offline OP
tampa florida
i have a 10 of 69, 70 r.r. that uses the 69 and older voltage regulator. factory wired, is this common? Factory shop manual shows electronic regulator
70 beep beep 383 N96 4spd 68 beep beep, eddy headed 383 4 spd 73 340 chally 73 340 duster
Re: 70 r.r. voltage regulator [Re: 1badrt] #2888032
02/14/21 11:33 AM
02/14/21 11:33 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Electronic regulators began to be equipped on some late big Chryslers/Imperials. As far I know these regulators were with 3 terminals ( dunno whyc ), so I find hard to think on 70 models some cars still were able to get mech regulators? Dunno.
Re: 70 r.r. voltage regulator [Re: 1badrt] #2888037
02/14/21 11:41 AM
02/14/21 11:41 AM
N
NITROUSN Offline
NITROUSN  Offline
N
My bets are someone replaced the harness. Never seen or heard of any factory wired that way.
Re: 70 r.r. voltage regulator [Re: NITROUSN] #2888048
02/14/21 12:03 PM
02/14/21 12:03 PM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
Agreed...never seen a 70 with the older regulator.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 r.r. voltage regulator [Re: NITROUSN] #2888064
02/14/21 12:37 PM
02/14/21 12:37 PM
tampa florida
1badrt Offline OP
1badrt  Offline OP
tampa florida
factory voltage regulator mounting holes for older regulator, not factory drilled for newer style, i would have to drill holes into firewall to mount newer style
Re: 70 r.r. voltage regulator [Re: 1badrt] #2888355
02/14/21 07:32 PM
02/14/21 07:32 PM
Lansing, MI
Lansing, MI
Something seems questionable here.....by 10/69 they were 3 full months into the 70 production year.....having a 69 and earlier voltage regulator bolt pattern on your firewall is very suspicious.
Re: 70 r.r. voltage regulator [Re: 70gtx440dana] #2888367
02/14/21 07:47 PM
02/14/21 07:47 PM
N
NITROUSN Offline
NITROUSN  Offline
N
70 parts and service manuals do not show anything either. All show the electronic style and alternator. I would like to see the car and all the body numbers.
Re: 70 r.r. voltage regulator [Re: 70gtx440dana] #2888408
02/14/21 09:15 PM
02/14/21 09:15 PM
Mass
charge70 Offline
charge70  Offline
Mass
If you remove the electronic voltage regulator bracket,the early regulator bolts right on.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 70 r.r. voltage regulator [Re: charge70] #2888449
02/14/21 10:20 PM
02/14/21 10:20 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Right. But the poster does not have that. He most likely has a old harness that was installed. His car originally had this mount.
Re: 70 r.r. voltage regulator [Re: 1badrt] #2888805
02/15/21 04:25 PM
02/15/21 04:25 PM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
My 70 GTX was a August 24, 1969 spd, Lynch Rd build and had an electronic regulator.
Re: 70 r.r. voltage regulator [Re: NITROUSN] #2889037
02/16/21 08:02 AM
02/16/21 08:02 AM
tampa florida
1badrt Offline OP
1badrt  Offline OP
tampa florida
where would you find that bracket, i have found several strange things on this car, hood mount turn signal wiring only had tight side connection
Re: 70 r.r. voltage regulator [Re: 1badrt] #2889084
02/16/21 10:37 AM
02/16/21 10:37 AM
Lansing, MI
Lansing, MI
Here you go:
Link 1
Link 2
Re: 70 r.r. voltage regulator [Re: 1badrt] #2889097
02/16/21 11:14 AM
02/16/21 11:14 AM
N
NITROUSN Offline
NITROUSN  Offline
N
That's because someone had their fingers in it and made it work to their liking. So nothing makes sense because nothing is original.
Re: 70 r.r. voltage regulator [Re: 70gtx440dana] #2889330
02/16/21 06:34 PM
02/16/21 06:34 PM
tampa florida
1badrt Offline OP
1badrt  Offline OP
tampa florida
thank you so much for your help
