Need more clearance main bearings #2885994
02/09/21 07:11 PM
02/09/21 07:11 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I need about .0005"- .001"or so more oil clearance and was wondering if any one bearing manufacturer has bearings that run a little thinner. I have clevites now. This is for main bearings for a low deck. I did call mahle about clevite bearings being available with an extra .001". They don't make them.
Re: Need more clearance main bearings [Re: varunner] #2886014
02/09/21 08:15 PM
02/09/21 08:15 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I've heard that King Engine bearings run on the thinner side, but I don't have first hand experience with em
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Need more clearance main bearings [Re: varunner] #2886016
02/09/21 08:20 PM
02/09/21 08:20 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Try King bearings.Have similar issue with an RB.King makes a .001 oversize and they are on the way.They can supply many different configurations to meet your needs. Call tech department, I did. Very helpful. Bill
Re: Need more clearance main bearings [Re: lancer493] #2886041
02/09/21 08:59 PM
02/09/21 08:59 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Thanks, I'll give them a call
Re: Need more clearance main bearings [Re: varunner] #2886063
02/09/21 09:41 PM
02/09/21 09:41 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Speed Pro 119M will give you about .001" more clearance than a Clevite. They are a very good bearing choice for high performance engines. And good luck finding King bearings (for BB Mopar)
in stock right now.
Brian
Re: Need more clearance main bearings [Re: '72CudaRacer] #2886183
02/10/21 08:24 AM
02/10/21 08:24 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
in stock right now.
Brian
The 119M is for RB mains. The OP has a Low Deck.
Re: Need more clearance main bearings [Re: cl440] #2886280
02/10/21 11:54 AM
02/10/21 11:54 AM
an8sec70cuda Offline
FWIW...every set of standard size King main bearings I've tried were tighter than the equivalent Speed Pro or Clevite.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Need more clearance main bearings [Re: an8sec70cuda] #2886296
02/10/21 12:20 PM
02/10/21 12:20 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
My crank is -.010 I found some -010 speed pro bearings(4094M10). I'll see what King has to offer and update.
Re: Need more clearance main bearings [Re: varunner] #2886300
02/10/21 12:38 PM
02/10/21 12:38 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Ok, so King doesn't offer a bearing with an extra .001" for a low deck. They did give me a dimension tor a standard -010 bearing thickness, so I can compare that to my clevites I already have. I'll try to update it again when I have it taken care of. thanks all.
Re: Need more clearance main bearings [Re: varunner] #2886378
02/10/21 03:13 PM
02/10/21 03:13 PM
I use that part number on most of my B motor stroker builds up
I usually have more than enough clearances but I do try to have the cranks ground down to the small size on the specs for both the rod and main journals when new being finished to the customers specs thumbs
Re: Need more clearance main bearings [Re: cl440] #2886652
02/11/21 08:54 AM
02/11/21 08:54 AM
Mooresburg, Tn
Mooresburg, Tn
in stock right now.
Brian
Yep, I missed that little detail. Sorry.
Brian
Re: Need more clearance main bearings [Re: '72CudaRacer] #2886658
02/11/21 09:40 AM
02/11/21 09:40 AM
A727Tflite Online content
A727Tflite  Online Content
No mention if this is a race motor or not, or if this is a new engine to you.
Have you checked the main bores for size ?
They may be on the small side.
Re: Need more clearance main bearings [Re: A727Tflite] #2886659
02/11/21 09:51 AM
02/11/21 09:51 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Race engine. Measured everything. I've already run it last year. The bearings don't look bad, but not great. I just want to loosen it a tad.
Re: Need more clearance main bearings [Re: varunner] #2886692
02/11/21 11:41 AM
02/11/21 11:41 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is sending the crank out to have the mains polished an option?
Shouldn't cost much more if any than a set of bearings, especially an orphan size bearing and it eliminates the future need for an orphan size bearing.
Kevin
Re: Need more clearance main bearings [Re: Twostick] #2886858
02/11/21 06:29 PM
02/11/21 06:29 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I wouldn't do that. Most people would not remove anymore than a tenth or so I think. Bearing manufacturers recommend to not polish crank journals, but I'm sure it's done all the time. I actually was at a shop recently to have some block work done, and brought my crank to polish. I doubt he removed enough to even measure. He used a cork belt.
I got some more bearing specs on thickness:
clevite fully grooved MS876P10 .1001 -.1006
sealed power fully grooved 4094M10 .1001-.1005
King half groove MB555HP010 .1001-.1005
So if the bearings are in spec, you'll get .0004 - .0005 variance.
Probably going to order some sealed power and see what I get.
Re: Need more clearance main bearings [Re: varunner] #2887031
02/12/21 02:42 AM
02/12/21 02:42 AM
Have you ever use red Scotchbrite pad and cleaning solvent on new bearings to increase the clearances?
I know several SO CA really good Mopar drag race engine builders that do use it to get the clearances they wanted back in the day, the trick is to not get real aggressive on using the pad, wipe it gently against the bearings shooting for a uniform finish while washing it under steady stream of solvent and then clean it thoroughly in hot soapy water and rinse it in hot clean water and blow dry it well before installing back into the bearing bores for measuring work scope wrench
I shoot for .0030+ on the main bearing clearances with both B and RB cranks and .0022+ on BB Chevy size rod journals and .0025+ on Mopar rod journals with 5W20Wt and 10W30 Wt. petroleum based oil, not synthetic oil twocents
With thicker oil add more clearances thumbs
Re: Need more clearance main bearings [Re: Cab_Burge] #2887045
02/12/21 06:16 AM
02/12/21 06:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You haven't mentioned your actual clearance numbers. What are they?
Doug
Re: Need more clearance main bearings [Re: dvw] #2887087
02/12/21 09:48 AM
02/12/21 09:48 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Cab, I definitely thought about that. I think I will try it on a used bearing.
Rods are at .003
mains .0023 average, varies a few tenths.
Re: Need more clearance main bearings [Re: varunner] #2887180
02/12/21 01:00 PM
02/12/21 01:00 PM
I did have to buy some of the King bearings on a recent build to get a little more clearances on Chevy 383 SB Stroker motor, instead of having the crank ground down .0015 work
Re: Need more clearance main bearings [Re: Cab_Burge] #2887311
02/12/21 04:50 PM
02/12/21 04:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Have you measured the block itself? I'll bet the main saddles are tight. I'm assuming the the journals measure correct?
Doug
