Re: Need more clearance main bearings
[Re: varunner]
#2886014
02/09/21 08:15 PM
02/09/21 08:15 PM
Posts: 271 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I've heard that King Engine bearings run on the thinner side, but I don't have first hand experience with em
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: varunner]
#2886063
02/09/21 09:41 PM
02/09/21 09:41 PM
Posts: 2,048 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Speed Pro 119M will give you about .001" more clearance than a Clevite. They are a very good bearing choice for high performance engines. And good luck finding King bearings (for BB Mopar) in stock right now.
Brian
[Re: '72CudaRacer]
#2886183
02/10/21 08:24 AM
02/10/21 08:24 AM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
Brian The 119M is for RB mains. The OP has a Low Deck.
[Re: cl440]
#2886280
02/10/21 11:54 AM
02/10/21 11:54 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
FWIW...every set of standard size King main bearings I've tried were tighter than the equivalent Speed Pro or Clevite.
[Re: an8sec70cuda]
#2886296
02/10/21 12:20 PM
02/10/21 12:20 PM
Posts: 661 Virginia
varunner
Virginia
My crank is -.010 I found some -010 speed pro bearings(4094M10). I'll see what King has to offer and update. *
[Re: cl440]
#2886652
02/11/21 08:54 AM
02/11/21 08:54 AM
'72CudaRacer
Mooresburg, Tn
Brian The 119M is for RB mains. The OP has a Low Deck. Yep, I missed that little detail. Sorry. Brian
[Re: Twostick]
#2886858
02/11/21 06:29 PM
02/11/21 06:29 PM
Posts: 661 Virginia
varunner
Virginia
I wouldn't do that. Most people would not remove anymore than a tenth or so I think. Bearing manufacturers recommend to not polish crank journals, but I'm sure it's done all the time. I actually was at a shop recently to have some block work done, and brought my crank to polish. I doubt he removed enough to even measure. He used a cork belt.
I got some more bearing specs on thickness:
clevite fully grooved MS876P10 .1001 -.1006 sealed power fully grooved 4094M10 .1001-.1005 King half groove MB555HP010 .1001-.1005
So if the bearings are in spec, you'll get .0004 - .0005 variance.
Probably going to order some sealed power and see what I get.
[Re: varunner]
#2887031
02/12/21 02:42 AM
02/12/21 02:42 AM
Posts: 43,219 Bend,OR USA
Cab_Burge
Have you ever use red Scotchbrite pad and cleaning solvent on new bearings to increase the clearances? I know several SO CA really good Mopar drag race engine builders that do use it to get the clearances they wanted back in the day, the trick is to not get real aggressive on using the pad, wipe it gently against the bearings shooting for a uniform finish while washing it under steady stream of solvent and then clean it thoroughly in hot soapy water and rinse it in hot clean water and blow dry it well before installing back into the bearing bores for measuring I shoot for .0030+ on the main bearing clearances with both B and RB cranks and .0022+ on BB Chevy size rod journals and .0025+ on Mopar rod journals with 5W20Wt and 10W30 Wt. petroleum based oil, not synthetic oil With thicker oil add more clearances
[Re: dvw]
#2887087
02/12/21 09:48 AM
02/12/21 09:48 AM
Posts: 661 Virginia
varunner
Virginia
Cab, I definitely thought about that. I think I will try it on a used bearing.
Rods are at .003 mains .0023 average, varies a few tenths.
