where can I find a 3 speed wiper switch for a 70 Cuda.
#288625
04/14/09 09:26 PM
04/14/09 09:26 PM
I have a new 3 speed wiper motor,converting from the 2 speed. I assume I need a different switch? how does the "park" mechanism work? with the 2 spd switch, I can make this 3 speed motor go two speeds, but no park.
Re: where can I find a 3 speed wiper switch for a 70 Cuda.
[Re: PAINT IT BLACK]
#288628
04/15/09 02:57 PM
04/15/09 02:57 PM
MoreParts
I bought one that supposedly worked on ebay last year. It didn't. I sure wish these were reproduced.
Jules restores these as I recall.
#288629
04/15/09 07:53 PM
04/15/09 07:53 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Not too hard to take the switch apart.. Most of the times the contacts are just pitted or corroded. Reburnish the contacts, coat with dia-electric grease and check for continuity. If good to go, then re-assemble.
Just my $0.02..
#288632
04/17/09 01:46 AM
04/17/09 01:46 AM
Posts: 118 Arkansas
hotrod98
Arkansas
If it won't park, you have a ground problem. There is a metal strip on the back side of the switch panel and it has to be grounded to the dash or the motor will not go to park. I've seen it a dozen times. Turn off the switch and take a grounded wire and touch the strip and see if I'm right.
You did change the wiper arm out inside the cowl? The 3-speed arm is totally different thatn the 2-speed arm. The pivot is different as well.
#288633
04/17/09 10:30 PM
04/17/09 10:30 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
jim_s@verizon.net My friend Jim restores mopar switches and does a very good job. Dimmer switches to with new windings. I send him all the e body switches I find. He does b body switches to. Honest man that does this on the side. Also rear defogger systems. You won't be sorry. He rebuilt my road lamp switch for me and also my heater switch. You may try giving him a shout. He lives in Pittsgurg Pa
