5.9 mag damper options, serpentine to belt conversion. #2885866
02/09/21 02:30 PM
02/09/21 02:30 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
Can't seem to find an answer in the search.
What harmonic balancer is used to replace the later 5.9 magnum one piece serpentine versions when converting to the older style LA front accessory cover/drives?
Want to use the parts from a 1990 5.9 tbi motor to simplify the future swap into a b250 van.
Been years since I have posted a question here. beer
1969 Dart
Re: 5.9 mag damper options, serpentine to belt conversion. [Re: Shaggy] #2885888
02/09/21 03:30 PM
02/09/21 03:30 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
Being told on another site to use the 94-97 5.9 damper and slot the offset bolt hole on the la pulley to fit.
1969 Dart
Re: 5.9 mag damper options, serpentine to belt conversion. [Re: Shaggy] #2885921
02/09/21 04:21 PM
02/09/21 04:21 PM
Guitar Jones Offline
You don't need to change the balancer. As has been said you can slot the offset hole in your LA pulley if it has one. The magnum balancer ring is thinner but the inner hub is in the same plane. What you may need to do is fab some brackets for the alternator mounting though as the head bolt bosses at the ends of the heads are not the same. You could however use the entire front accessory drive, The alternator and power steering pump will still work with a earlier wiring harness. Did you plan on using the TBI setup?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 5.9 mag damper options, serpentine to belt conversion. [Re: Guitar Jones] #2886052
02/09/21 09:09 PM
02/09/21 09:09 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
The 5.9 mag engine I have is a later version and has the one piece damper with the built in serpentine belt pulley.
Not going to be using the TBI setup, It will be a sniper efi or carb I already have depending on how budget constraints work out.
Re: 5.9 mag damper options, serpentine to belt conversion. [Re: Shaggy] #2886060
02/09/21 09:33 PM
02/09/21 09:33 PM
Then any year prior to that would work, '93 to ? I don't know when that changed. What year is your engine?
Lots of info at magnumswap.com
Re: 5.9 mag damper options, serpentine to belt conversion. [Re: Guitar Jones] #2886164
02/10/21 04:56 AM
02/10/21 04:56 AM
Here is an aftermarket damper. balancer
Re: 5.9 mag damper options, serpentine to belt conversion. [Re: Shaggy] #2889374
02/16/21 07:54 PM
02/16/21 07:54 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
This is the correct answer. The 1990 TBI engine you have a balancer from has a different offset weight than the magnum engines so it will not balance properly. If you don't want to do the bolt on weights here are some options on ebay (not mine).
The 20 dollar used option
The 70 dollar new replacement option
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: 5.9 mag damper options, serpentine to belt conversion. [Re: Michael Ecks] #2889379
02/16/21 08:09 PM
02/16/21 08:09 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
My wifes 01 van 5.9 has the 2 piece still on it. Use one for a magnum 5.9 from 93-01, the only problem I seen is the parts store now only will give me a one piece to retrofit them back to 93.
My question though is why not use the serp belt set up? They work awesome.
