Opinions on Magnafuel 275 pump #288546
04/14/09 07:56 PM
04/14/09 07:56 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
Anyone have experience with the Magnafuel 275 pump, thinking of upgrading my fuel system.
Re: Opinions on Magnafuel 275 pump *DELETED* [Re: nss guy] #288547
04/14/09 08:07 PM
04/14/09 08:07 PM
Post deleted by SUPERSTOCKRACER
Re: Opinions on Magnafuel 275 pump *DELETED* #288548
04/14/09 08:17 PM
04/14/09 08:17 PM
Re: Opinions on Magnafuel 275 pump #288549
04/14/09 08:59 PM
04/14/09 08:59 PM
central ohio
N
nss guy Offline OP
nss guy  Offline OP
N
central ohio
Thanks for the input,
Anyone else?
Re: Opinions on Magnafuel 275 pump [Re: nss guy] #288550
04/14/09 11:23 PM
04/14/09 11:23 PM
I used one on my Duster with the #10 feed to the pump,#8 bypass and #8 line to the four port BG regulator at the front of the motor feeding a six pak. The car ran a best of 10:34 at 128.6 MPH, I later found out it was runing out of fuel according to my Innovate LM1, it was reading correctly. I replaced that one with a Magnafuel 300 and I now wish that I had bought the Magnafuel 500 pump to start with The motor started out as a 512 C.I. low deck stroker motor with ported 906 heads and 9.25 to 1 compression ratio, that combination made 612 HP at 5500 RPM and 544 ft. lbs at 4500 rpm. I have since switch heads to a set of Eddy RPM CNC ported heads and added .050 stroke to raise the compression ratio up to 10.29 to 1, this combination has made 718 HP at 5800 RPM and 740 Ft lbs at 4800 RPM so far Magnafuel told me that thier 275 pump was good to 750 HP, maybe standing still on a engine dyno but not in my car, buy the best one now and avoid replacing it later when you hop the car up some more
Re: Opinions on Magnafuel 275 pump [Re: Cab_Burge] #288551
04/14/09 11:29 PM
04/14/09 11:29 PM
Nazareth,Pa.
JACKSON Offline
JACKSON  Offline
Nazareth,Pa.
they are good
Re: Opinions on Magnafuel 275 pump [Re: Cab_Burge] #288552
04/14/09 11:33 PM
04/14/09 11:33 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
no need in having to worry about upgrading the pump later on
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
Re: Opinions on Magnafuel 275 pump [Re: nss guy] #288553
04/15/09 12:12 AM
04/15/09 12:12 AM
central Ohio
SnakeEisz67 Offline
SnakeEisz67  Offline
central Ohio
Ran one 9 years in my Valiant 446 ci with Indy-1 heads. Ran best of 10.16 & 132 mph. Had to replace seals once 2 years ago. No issues besides that. Upgraded to 499 ci last yr. but haven't ran a 1/4 yet with it. Only a few passes in the 1/8 late last year for shakedown. Will be curious if I have issues with fresh 499.
Re: Opinions on Magnafuel 275 pump [Re: nss guy] #288554
04/15/09 08:31 AM
04/15/09 08:31 AM
Sterling Hts, MI
2
2FASTCORONET Offline
Sterling Hts, MI
I think they are good for 750HP, I have one with a filter on my Coronet 600HP, never have had a problem in three years. Dennis
