motor plate pics #2884198
02/05/21 02:54 AM
02/05/21 02:54 AM
BigFish69 Offline OP
looking for ideas on mounting accessories on the motor plate alt. vac. pump ect. pics would be helpful.
thanks
Re: motor plate pics [Re: BigFish69] #2884318
02/05/21 12:34 PM
02/05/21 12:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
This is mine.
Doug
Re: motor plate pics [Re: dvw] #2884490
02/05/21 08:00 PM
02/05/21 08:00 PM
wow Doug that plate looks full
Re: motor plate pics [Re: dvw] #2884503
02/05/21 08:50 PM
02/05/21 08:50 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Originally Posted by dvw
This is mine.
Doug
That looks nice! What alternator is that?
Re: motor plate pics [Re: mopowers] #2884508
02/05/21 09:02 PM
02/05/21 09:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
East coast mini. To be honest if I did it again Id put the alternator below the vacuum pump. Then run a larger alternator.
Doug
Re: motor plate pics [Re: BigFish69] #2884559
02/05/21 11:21 PM
02/05/21 11:21 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
Just added the vac pump last year because all the cool kids have them smile ....just have to step up in the crank trigger department
Re: motor plate pics [Re: J_BODY] #2884567
02/05/21 11:37 PM
02/05/21 11:37 PM
J body does that alt. bolt to the plate or into the block ?
Re: motor plate pics [Re: J_BODY] #2884571
02/05/21 11:40 PM
02/05/21 11:40 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I take it when you put it in the car you hooked the vacuum pump up to the suction side?
Joe
Without Data, you’re just another guy with an opinion.
Re: motor plate pics [Re: sr4440] #2884581
02/06/21 12:37 AM
02/06/21 12:37 AM
aZLiViN
aZLiViN
Yeah we corrected that.... good eye!
Alt is bolted to the plate. Wish I had a better pict of the bracket. Only part that gets swapped between our two engines.
Re: motor plate pics [Re: J_BODY] #2885774
02/09/21 09:26 AM
02/09/21 09:26 AM
an8sec70cuda Offline
Best one I have at the moment...
CHIP
'06 GMC 2500HD LBZ Duramax
Re: motor plate pics [Re: an8sec70cuda] #2885778
02/09/21 09:32 AM
02/09/21 09:32 AM
aZLiViN
aZLiViN
No alternator chip?
Re: motor plate pics [Re: J_BODY] #2885790
02/09/21 09:55 AM
02/09/21 09:55 AM
No alternator chip?
Yes, it has a DMI low mount kit on it, just hadn't put it back on it yet when that pic was taken. Didn't even realize that, lol.
CHIP
Re: motor plate pics [Re: an8sec70cuda] #2885791
02/09/21 09:59 AM
02/09/21 09:59 AM
Found one w/ the alternator...
CHIP
Re: motor plate pics [Re: an8sec70cuda] #2885804
02/09/21 10:56 AM
02/09/21 10:56 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
My plate ties the front rollbar struts AND the lower frame rails. I have the Indy rev adapter plate and a SBC waterpump (which I'd do differently and just use a remote pump on the radiator)
Re: motor plate pics [Re: HardcoreB] #2886071
02/09/21 10:14 PM
02/09/21 10:14 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
16 years ago........Vince Impasato and Chuck Millen from Best Machine in Michigan when I flew in on dyno day. The motor plate was definitely a beefy piece.
"Any fool can know. The point is to understand"
- A. Einstein
Re: motor plate pics [Re: EvilB1Dart] #2886125
02/10/21 12:39 AM
02/10/21 12:39 AM
no mans land
racerbychoice Offline
no mans land
do you guys all use mid-plates when you use a motor-plate?
dj
Re: motor plate pics [Re: EvilB1Dart] #2886139
02/10/21 01:14 AM
02/10/21 01:14 AM
thanks for the pictures im working with a small block for the first time lot less room to work with then the big blocks height wise.
Re: motor plate pics [Re: racerbychoice] #2886170
02/10/21 06:22 AM
02/10/21 06:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No mid plate with mine. but it does have struts on the trans to control fore/aft movement.
Doug
Re: motor plate pics [Re: BigFish69] #2886190
02/10/21 08:57 AM
02/10/21 08:57 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Then kick the plate upward from it's mounting source on the block. If you can see well in my fuzzy pic that's what i did to gain material and again it ties to the upper cage struts.
Re: motor plate pics [Re: dvw] #2886191
02/10/21 08:58 AM
02/10/21 08:58 AM
aZLiViN
aZLiViN
No mid plate here either.... but my fore/aft link is off my front frame to the block. Doug utilized one of the trans mounts I use as a shift cable mount on his set up smile
