Re: window tint glue removal ?
[Re: blaze]
#2884677
02/06/21 12:24 PM
02/06/21 12:24 PM
Posts: 16,492 On the run…
BloFish
On the run…
Goof off works well with a razor blade.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Ramtough]
#2884764
02/06/21 04:51 PM
02/06/21 04:51 PM
Posts: 1,030 ohio
67mprfan
ohio
Windex and razor blade just keep glass wet this is how I've done it in the past
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: EDDIEB]
#2886206
02/10/21 10:04 AM
02/10/21 10:04 AM
RWG75
RWG75
Whatever carb / brake cleaner ya got laying around should do it. Spray it on, let it soak, scrap it off, revisit with cleaner on a rag as needed. Not sure I ever used it for window tint but it works for inspection stickers, those big nasty "tow me away" stickers, rear view mirror adhesive......
[Re: ]
#3105736
12/26/22 04:54 PM
12/26/22 04:54 PM
FrankUnderwoodd
FrankUnderwoodd
A razor blade is the best in such cases, and a simple windows cleaning solution afterward. It should help. This is one of the reasons I don’t like tinting – it’s not easily removable and doesn’t look that good when damaged. That’s why I prefer using magnetic fabric sunshades with extensive UV protection in my car. These are easily removable and protect the insides of the vehicle from sun radiation well. The area where I live is rather gloomy, and sometimes, I want more light in my car. Tinting would make it difficult for me to drive on days that are already too dark to see well.
