Tire pressure thoughts and what do you run?
#288124
04/14/09 10:50 AM
04/14/09 10:50 AM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Just curious what others running big Goodyear or other brands of slicks are running for tire pressures. I run a 2078 Goodyear and have been at 8.5-8.75lbs. The Hemi worked well at that pressure but it was also making about 200 less HP than the current engine. The reason I ask is I was, still am talking to a very good Top Sportsman crewchief after this passed weekends wheelstand escapade and through the course of the conversation he asked me what my tire pressure was. He told me I need to go lower by quite a bit actually. He said when the track was tight, as it was Saturday that they lower their air pressure by as much as 1/2 lb. The reasoning was to help build wheelspeed. He went on to explain that what takes place is the lower pressure causes the center of the tire to cup reducing the contact patch, thus giving the needed wheelspeed instead of dead hooking the car. I went back home Saturday night and watched some video we have of faster cars from behind and I can see what he is referring to, most all of them have the tires slightly cupped. He explained when tracks are not as tight, or do not have a ton of bite that they will up the pressure allowing the tire to have a bigger contact patch. It made sense to me just curious what others take on this is. Any thoughts, ideas? Oh yeah I have had my fill, of this as well.
Re: Tire pressure thoughts and what do you run?
[Re: Al_Alguire]
#288127
04/14/09 11:43 AM
04/14/09 11:43 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have always gone UP in pressure to get the wheel speed on tight tracks and lower on lesser tracks. When going lower on tight tracks you have a greater issue of tire shake(tires trying to drive over itself) a 1/2 pound can mean aot but all cars act differently
[Re: Al_Alguire]
#288129
04/14/09 12:03 PM
04/14/09 12:03 PM
Al_Alguire
Las Vegas
I guess one other little tidbit or piece of info that might be useful to others is what type of car and how much power are you putting down. I think this is an iportant detail of the equation.
So in that vane I will go first. 2840lb tube car with struts and a 4 link. Engine made 1050 on the dyno but since fuel change I have picked up 2mph+(A-B-A test)so may be a tad more now.
Post deleted by Defbob
[Re: MR_P_BODY]
#288131
04/14/09 06:14 PM
04/14/09 06:14 PM
#288132
04/14/09 06:34 PM
04/14/09 06:34 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
use a good calibrated gauge and check often big slicks can change 1 psi just by the weather getting 5 deg warmer and opposite as night falls. like 9 lbs at rest pressure will go about to 9.6 after the burnout. also check press after the run return road so you know ho the friction coefficient heated the tires top end if you were running too low to start it will get much hoter and squirrley on big end. optimise the patch contact based on the roughness and rubber quality already laid down. good idea to have a crew member check before burnout, after burnout.and walk on the start line rubber with rubber shoes to calibrate the "stickness" and adj appropiatle. eventually it becomes second nature. also remember a 1/2 psi diff side to side will cause drifting and we dont usually want that.a durometer test of the tires daily is best. i would put in a perm optical pyrometer over each rear tire and one of them modern pressure transmitters found on the expensive cars now on each tire. leave NOTHING to chance as the start line is random enough as is
[Re: Al_Alguire]
#288140
04/14/09 09:33 PM
04/14/09 09:33 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Al,
You may get several different opinions on what the added or subtracted tire pressure actually does. When we run our car your outlined way is exactly how we pursue it. If you get up too high in pressure, though, the tire will quit working. On our deal we use more pressure than you do and I know that several of the competitors in our class do too. Believe me when I say that we are usually looking for more bite. We also find that dead hooking yields the best ET's. You may have to do some chassis work and possibly move some weight around to keep from wheel standing. Also, lower your traction bars to keep the car from getting a lot of rearward momentum.
[Re: BobR]
#288141
04/15/09 01:24 AM
04/15/09 01:24 AM
Al_Alguire
Las Vegas
Well thanks for the input fellas. Goodyear actually suggested I run 6.5-7lbs with these tires,power and weight. I have not gone below 8.25 as of yet, we have been as high as 10.0.
Ron as you know and have seen in person the car still hits the tire plenty hard. Was talking with Gillettes(VG TS team out here)crew chief, he was the one suggesting the change and asking. me what I was running. As for the bars, we can all agree they are pretty much window dressing. They dont do much really. We did collapse the springs fully today and lowered them a bit, will see what that does. I am waiting to take the car to Sarmento to get some new ones whittled up. I am just a number in line right now.
[Re: Al_Alguire]
#288142
04/15/09 01:51 PM
04/15/09 01:51 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
Well once you get those new longs outback things are gonna change for the better...I might be up there the first weekend in May at the track...but Dragfest is also that weekend and my Fiat will be in Bakersfield....right now it looks like I'm going to Sac and my car is heading to Bako...LOL....and sorry I cant just run up there and throw you a set on...but we are going 18 hours a day right now with no end in sight.
