Tire pressure thoughts and what do you run? #288124
04/14/09 10:50 AM
04/14/09 10:50 AM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Just curious what others running big Goodyear or other brands of slicks are running for tire pressures. I run a 2078 Goodyear and have been at 8.5-8.75lbs. The Hemi worked well at that pressure but it was also making about 200 less HP than the current engine.
The reason I ask is I was, still am talking to a very good Top Sportsman crewchief after this passed weekends wheelstand escapade and through the course of the conversation he asked me what my tire pressure was. He told me I need to go lower by quite a bit actually. He said when the track was tight, as it was Saturday that they lower their air pressure by as much as 1/2 lb. The reasoning was to help build wheelspeed. He went on to explain that what takes place is the lower pressure causes the center of the tire to cup reducing the contact patch, thus giving the needed wheelspeed instead of dead hooking the car. I went back home Saturday night and watched some video we have of faster cars from behind and I can see what he is referring to, most all of them have the tires slightly cupped. He explained when tracks are not as tight, or do not have a ton of bite that they will up the pressure allowing the tire to have a bigger contact patch.
It made sense to me just curious what others take on this is. Any thoughts, ideas?
Oh yeah I have had my fill, of this as well.
Re: Tire pressure thoughts and what do you run? [Re: Al_Alguire] #288125
04/14/09 11:04 AM
04/14/09 11:04 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Al not that I have big tires, but it sounds like it should work.Then again why not go to a skinny tire like a 10.5 and it would give the same thing?Top fuel tires are always cupped.
Re: Tire pressure thoughts and what do you run? [Re: Al_Alguire] #288126
04/14/09 11:05 AM
04/14/09 11:05 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
http://www.popularmechanics.com/automotive/motorsports/1269381.html
Maybe that link will shed some light ..
Guess you can try what he suggested and see what it does ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Tire pressure thoughts and what do you run? [Re: Al_Alguire] #288127
04/14/09 11:43 AM
04/14/09 11:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have always gone UP in pressure to get the wheel speed
on tight tracks and lower on lesser tracks. When going
lower on tight tracks you have a greater issue of
tire shake(tires trying to drive over itself) a 1/2
pound can mean aot but all cars act differently
Re: Tire pressure thoughts and what do you run? [Re: MR_P_BODY] #288128
04/14/09 11:45 AM
04/14/09 11:45 AM
Q
Quicktree Offline
Quicktree  Offline
Q
as much as I can
Re: Tire pressure thoughts and what do you run? [Re: Al_Alguire] #288129
04/14/09 12:03 PM
04/14/09 12:03 PM
Las Vegas
Las Vegas
I guess one other little tidbit or piece of info that might be useful to others is what type of car and how much power are you putting down. I think this is an iportant detail of the equation.
So in that vane I will go first. 2840lb tube car with struts and a 4 link. Engine made 1050 on the dyno but since fuel change I have picked up 2mph+(A-B-A test)so may be a tad more now.
Re: Tire pressure thoughts and what do you run? [Re: Al_Alguire] #288130
04/14/09 01:13 PM
04/14/09 01:13 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
On my Duster it weighs 2400# with me in it. 17.0 x 33.5 x 16 tires. Last year with a 750hp motor I ran the pressure at 6.5# and it worked fine so I didn't play with it any...just bracket racing. This year I have a 1100hp motor but haven't run the car yet so we'll see. I'm gonna start at 6.5# and go from there.
Post deleted by Defbob [Re: MR_P_BODY] #288131
04/14/09 06:14 PM
04/14/09 06:14 PM
Re: Tire pressure thoughts and what do you run? #288132
04/14/09 06:34 PM
04/14/09 06:34 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
use a good calibrated gauge and check often
big slicks can change 1 psi just by the weather getting 5 deg warmer and opposite as night falls.
like 9 lbs at rest pressure will go about to 9.6 after the burnout. also check press after the run return road so you know ho the friction coefficient heated the tires top end
if you were running too low to start it will get much hoter and squirrley on big end.
optimise the patch contact based on the roughness and rubber quality already laid down.
good idea to have a crew member check before burnout, after burnout.and walk on the start line rubber with rubber shoes to calibrate the "stickness" and adj appropiatle.
eventually it becomes second nature.
also remember a 1/2 psi diff side to side will cause drifting and we dont usually want that.a durometer test of the tires daily is best.
i would put in a perm optical pyrometer over each rear tire and one of them modern pressure transmitters found on the expensive cars now on each tire. leave NOTHING to chance as the start line is random enough as is
Re: Tire pressure thoughts and what do you run? #288133
04/14/09 07:19 PM
04/14/09 07:19 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
x2....but in some cases lowering can help wheel speed....OR it can cause extreme wading...Al...wish I had a better picture of that rear angle wheelie.....I'd like to see the black tracks.
Re: Tire pressure thoughts and what do you run? [Re: Chassisman] #288134
04/14/09 07:27 PM
04/14/09 07:27 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I ran the largest softest Good Year Tires that is offered for a 15" diameter wheel. Think they were 17x34 IIRC. Anyways On a marginal track, the car picked up from a 1.14-1.16 short times, to consistent 1.07-1.08 short times. This was going from 7-7.5LBS to 5-5.5 lbs. FWIW
MPH actually didnt change much (even though I picked up .15 seconds overall), I guess due to spinning and wheel speed. About 143-144mph in the 8th
Re: Tire pressure thoughts and what do you run? [Re: HemiGreg] #288135
04/14/09 07:29 PM
04/14/09 07:29 PM
NC
440Jim Offline
440Jim  Offline
NC
WOW, bigger league than me.
My little tire is about 14 x 32 and I run 11.0 psi with 700ish horsepower at 3190 lbs. But I dead-hook, not wheelspeed (bracket racing).
Re: Tire pressure thoughts and what do you run? [Re: 440Jim] #288136
04/14/09 07:31 PM
04/14/09 07:31 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Yeah me too we have been playing with air pressure the last few weeks 14x32 also and my car likes no less that 8 and no more than 10
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Tire pressure thoughts and what do you run? [Re: Chassisman] #288137
04/14/09 07:36 PM
04/14/09 07:36 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
I also just noticed something.....your wheelie bars arent doing you much good at all.....ya...they are keeping it from tail standing BUT...those poor things have absolutely NO leverage to help control the wheelie.You REALLY need longer wheelie bars for that car....yes they are a pain....but you need them to make that thing fly !
And those bars have been on that car for 5 years and arent bent...oh...and it's won A/Gas at the March Meet 2 of the last 3 years...also has won alot of other 7.60 index classes.
This shot is with the wheelie bar 1" higher than the first pic !!!!!!
The car has a PG also...no fancy clutches to tune...torque multipliers suck at times when it comes to controling the launch...especially in cars with engine set back...
Re: Tire pressure thoughts and what do you run? [Re: Al_Alguire] #288138
04/14/09 08:51 PM
04/14/09 08:51 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Well, I have a thought,... if you lower pressure the contact patch gets longer. More of a "tangent" if you will area between the track and the tire, you can actually watch that area get longer as you reduce pressure. Not sure what that means and how that and cupping interact. I am like 440Jim, a bracket racer which my thinking is trying to get close to a dead hook to make it the most consistant. I run about 9 lbs in a 14-32W-15 on a 15" wide rim with a heavier much less powered back-halved 4-link car which probably means absolutely nothing in this situation. But thats what I run anyway.... Good Luck
Re: Tire pressure thoughts and what do you run? [Re: HemiGreg] #288139
04/14/09 09:31 PM
04/14/09 09:31 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I will tell you it can cause much worse than a little drifting. I had 1 psi different from one side to the other by accident and when the front end came up it hooked so hard I almost hit the tree.
I'm not in the same leage HP wise but I found the launch was much too violent when the pressure was too low. The car still hooked but it wound the tires up like a spring. More pressure really smoothed out the launch. I'm about the same weight as you but 200 less HP.
Re: Tire pressure thoughts and what do you run? [Re: Al_Alguire] #288140
04/14/09 09:33 PM
04/14/09 09:33 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Al,
You may get several different opinions on what the added or subtracted tire pressure actually does. When we run our car your outlined way is exactly how we pursue it. If you get up too high in pressure, though, the tire will quit working. On our deal we use more pressure than you do and I know that several of the competitors in our class do too. Believe me when I say that we are usually looking for more bite. We also find that dead hooking yields the best ET's. You may have to do some chassis work and possibly move some weight around to keep from wheel standing. Also, lower your traction bars to keep the car from getting a lot of rearward momentum.
Re: Tire pressure thoughts and what do you run? [Re: BobR] #288141
04/15/09 01:24 AM
04/15/09 01:24 AM
Las Vegas
Las Vegas
Well thanks for the input fellas. Goodyear actually suggested I run 6.5-7lbs with these tires,power and weight. I have not gone below 8.25 as of yet, we have been as high as 10.0.
Ron as you know and have seen in person the car still hits the tire plenty hard. Was talking with Gillettes(VG TS team out here)crew chief, he was the one suggesting the change and asking.
me what I was running. As for the bars, we can all agree they are pretty much window dressing. They dont do much really. We did collapse the springs fully today and lowered them a bit, will see what that does. I am waiting to take the car to Sarmento to get some new ones whittled up. I am just a number in line right now.
Re: Tire pressure thoughts and what do you run? [Re: Al_Alguire] #288142
04/15/09 01:51 PM
04/15/09 01:51 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Well once you get those new longs outback things are gonna change for the better...I might be up there the first weekend in May at the track...but Dragfest is also that weekend and my Fiat will be in Bakersfield....right now it looks like I'm going to Sac and my car is heading to Bako...LOL....and sorry I cant just run up there and throw you a set on...but we are going 18 hours a day right now with no end in sight.
Re: Tire pressure thoughts and what do you run? [Re: Chassisman] #288143
04/15/09 02:24 PM
04/15/09 02:24 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Between 19.5 and 22.5 psi on my 28x13.5 ET streets on 10" wheel....with the Auto Trans. I'll probably try 25psi with the stick shift, because I want a little spin coming out of the hole.
