SB Hyd roller lifters.... #288036
04/14/09 04:30 AM
04/14/09 04:30 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Hey guys, other than the Comp hyd rollers (8920-16) who else makes a juice roller lifter for a SB?
The Comps are very pricey, what other alternatives are there?
Also out of curiosity, what kinda spring/seat pressure can OEM roller lifters take? I know they're different to the drop in Comp Cams lifters, but this is for a custom gig
Any info would be killer thanx !!
Rat
Re: SB Hyd roller lifters.... [Re: LAD 524] #288037
04/14/09 08:56 AM
04/14/09 08:56 AM
scratchnfotraction Offline
my 100,000 mile stock roller lifters
have 2 yrs so far with a lunati 60710 voodoo roller cam-.485 lift and comp 901 springs
has stock oil through roller lifters,push rods,stock rockers
oils both the rocker shafts and through the lifters/PR
maybe thats a starting point for you,not much over stock right there..so I would say thats the lowest you can go performance wize
some one here on the board had some real nice roller lifters with some mods to them that fixed some of the probs with sb rollers
some thing about uncovering the oil gally or something
maybe the will chime in I think it was OU812
Re: SB Hyd roller lifters.... [Re: scratchnfotraction] #288038
04/14/09 09:51 AM
04/14/09 09:51 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The ones ou812 has are solid rollers with the advantage that the link bar is toward the inside of the engine so no block clearancing is needed. And they pressure oil the roller too if I remember corrrectly.
I run the Crane Hydraulic rollers which are just about the same of the Comps but Crane is out of business right now.
Re: SB Hyd roller lifters.... [Re: LAD 524] #288039
04/14/09 10:59 AM
04/14/09 10:59 AM
SoCal
Brian Hafliger Online content
Brian Hafliger  Online Content
SoCal
Early or late block??
Brian Hafliger
Re: SB Hyd roller lifters.... [Re: Brian Hafliger] #288040
04/17/09 06:15 AM
04/17/09 06:15 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Its an early block.
The OEM lifter is an oil thru the pushrod design while the old 360 block oils thru the deck.
Any issues with this??
Rat
Re: SB Hyd roller lifters.... [Re: LAD 524] #288041
04/17/09 08:22 AM
04/17/09 08:22 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Factory hyd roller lifters will not work in a non-roller block, unless you bush the bores and make them approx 0.4" taller. The old lifter bosses are too short.
You *might* get by if you used a ridiculously small base circle cam. then you'd still have to mount the spider that hold the dog bones.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: SB Hyd roller lifters.... [Re: BBR] #288042
04/17/09 09:16 AM
04/17/09 09:16 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
it would be hard to convert an old block to the factory rollersetup. The guide bars are held by the lifter bosses from moving and the spider thing just holds them down.
87 dakota 6.1 hemi
Re: SB Hyd roller lifters.... [Re: Glen440] #288043
04/17/09 12:32 PM
04/17/09 12:32 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
http://store.summitracing.com/partdetail.asp?part=CRO-66325-16&autoview=sku
crowers are $170 cheaper than the comps on summit.
2017 Grand Cherokee Overland
Re: SB Hyd roller lifters.... [Re: patrick] #288044
04/19/09 10:18 AM
04/19/09 10:18 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Patrick thanx for that.
Do the Crower roller lifters have the oil groove machined lower in the body to prevent the oil pressure bleeing off ?
Are these Crower lifters retro fit drop in lifters like the Comps are?
Rat
