Procharger Water Meth / Holley Sniper #2880327
01/26/21 10:30 AM
01/26/21 10:30 AM
Tampa FL
BillR1212 Offline OP
Tampa FL
Hi Team,
Quick question... my air temps are running 140 + on my quarter mile pulls. I opted for water/meth on my procharger for a few reasons. It's my understanding that a blow through throttle body benefits from cooling from mixing air and fuel. secondly water meth should help cool the air prior. My remote tuner is pulling timing once I hit 140 MAT. My thought is that we should be seeing more cooling after the throttle body, and the bottom of the intake runner. With that said, I can't find anything online with this data to prove it (specific to throttle body EFI at least). I'm tempted to pull the intake and put my own probe in the runner so I can see the difference in temps. However, I wanted to see if you guys have thoughts on it. My remote tuner is saying that because the sniper is under pressure, the cooling is not as effective as a carbonated low pressure environment. Anyone have data here to support either way? (I found a youtube video of somebody running E85 on a carb and the air temps were cut in half from throttle body to bottom of plenum)
Hopefully this isn't a dumb question. I'm new to this world of tuning with EFI and boost. However my car is not pulling like it should at the big end. I feel that my Edelbrock RPM (CNC ported) heads are my limiting factor. I did not build the engine for boost originally. Either way, having timing pulled, and high air temps is also not helping.
Thank you
Re: Procharger Water Meth / Holley Sniper [Re: BillR1212] #2880345
01/26/21 11:09 AM
01/26/21 11:09 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If they are applicable, there are meth injection threads over on Hellcats.org. The one take-away that I got from the posts is that the Hellcat guys don't run meth injection much because they are afraid of a delivery failure resulting in a meltdown. They (along with Dodge) concentrate on bringing in outside air and cooling it with the chiller. Which is basically the A/C system cooling the intercooler. Much more complicated, but considered to be dependable. Then they insulate the blower intake from the heads. Etc, etc, etc.
Can't you at least get ambient temp air to the engine?
Master, again and still
Re: Procharger Water Meth / Holley Sniper [Re: DaveRS23] #2880348
01/26/21 11:20 AM
01/26/21 11:20 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I would ditch the water/meth in favor of an intercooler if IAT is your concern.
Re: Procharger Water Meth / Holley Sniper [Re: INTMD8] #2880365
01/26/21 11:58 AM
01/26/21 11:58 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Call The Super Charger Store and talk with them.....They swear by the water meth kits, I have a friend locally that was running one and said it didn't help at all and switched over to E85 so he could boost as much as he wanted. I also have a Sniper and I am curious what you find out.
Re: Procharger Water Meth / Holley Sniper [Re: Dragula] #2880376
01/26/21 12:36 PM
01/26/21 12:36 PM
Tampa FL
Tampa FL
Thanks Team - I agree that with modern injection systems the water meth is not delivered to all cylinders in a uniform fashion. Mainly because the runners are not designed to transfer a wet mixture being port injection. ( I think). Where as the single plane intake is designed exactly for that... Supercharger store has provided me with all sorts of cooling data, but I'm not seeing that in my own system. (It's where I bought the kit from). I do not have much room in the engine bay. It's an e body Cuda. I'd love an intercooler, but not sure how I can accomplish it, without 5 grand of custom fab work, and making getting to plugs, and belts even more of a pain in the ***. If anyone has a procharger big block e body, that is intercooled. I'll gladly take ideas. I found a few pics online. (my brake booster and master cylinder eat up a lot of real estate for the air cleaner, so fresh air is tough. I cut opened up the fake vents on the hood, but I'm guessing that not too much fresh air is being forced in there.
Re: Procharger Water Meth / Holley Sniper [Re: BillR1212] #2880399
01/26/21 01:23 PM
01/26/21 01:23 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Then why dont you put direct port water injection like the nitrous guys use........
Re: Procharger Water Meth / Holley Sniper [Re: BillR1212] #2880423
01/26/21 02:14 PM
01/26/21 02:14 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
BillR1212- I am not running a Sniper, but am running a Holley throttle body with multiport ran by HP EFI with Holley's water methanol kit. I have water methanol injection nozzle in the carb hat and it works well. I have had an instance where the injection did not come on and I think I saw similar temps of around 140° F, but typically see high 90s°- 103°F during a 1/4" mile pass.
Re: Procharger Water Meth / Holley Sniper [Re: 416challenger] #2880429
01/26/21 02:35 PM
01/26/21 02:35 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Looks like plenty of room for an air/air in front of the radiator, or mount an air/water anywhere. If you can do any fab work it wouldn't be expensive.
Re: Procharger Water Meth / Holley Sniper [Re: 416challenger] #2880586
01/26/21 07:18 PM
01/26/21 07:18 PM
Tampa FL
Tampa FL
Wow - Those are good temps. Per the supercharger store, I'm running my water/meth before the blower. Should I change it to post blower?
Re: Procharger Water Meth / Holley Sniper [Re: INTMD8] #2880587
01/26/21 07:20 PM
01/26/21 07:20 PM
Tampa FL
Tampa FL
You're correct, there is room for air to air, it's just the piping to get it there. I'm not a fabricator sadly. It would likely be an expensive job. In theory the water meth should work for me.
Re: Procharger Water Meth / Holley Sniper [Re: BillR1212] #2880606
01/26/21 07:43 PM
01/26/21 07:43 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have looked into lowering the IAT on my roots blown HEMI. W/M is supposed to be good for 50/60* I went with N2O that comes out of the bottle @ 130* and hope to see 100* decrease in IAT. Supposedly 135* or better is ideal.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Procharger Water Meth / Holley Sniper [Re: BillR1212] #2881419
01/28/21 06:05 PM
01/28/21 06:05 PM
Any time you compress air you will heat it up, I've seen 130 IAT on a pump gas Roots blown with 7.5 lbs. of boost at 7300 RPM making 924 HP , that motor had a Littlefield 10-71 blower with two carb shop 1050 CFM Dominator blower carbs on it, it was 12% under driven for those tests using 91 octane CA pump swill back in 2001, we switch the pulleys around to get 13% over drive and got 12.0 lbs. of pressure at 6500 RPM making 1027 HP when the motor started going into detonation on 110 octane race gas with 190 F IAT shock shruggy
Hot air expands, especially when compressed, and that leans the motor out. Cooling the intake air will make more power based on more air and fuel getting into the motor which will make more power up scope
Good luck on this wrench, you can fix it thumbs
Re: Procharger Water Meth / Holley Sniper [Re: BillR1212] #2881653
01/29/21 11:18 AM
01/29/21 11:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I used a Snow kit on a 440-6 car, it worked great, not sure why it wouldn't work on a supercharged car. You can place the nozzles were ever you like, or just use a plate or a combo of both. They make various kit specifically for boosted applications.
Coming soon!!!!
Re: Procharger Water Meth / Holley Sniper [Re: Mr.Yuck] #2881670
01/29/21 11:56 AM
01/29/21 11:56 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Cool....can you post pictures of the nozzle set-up on your 6 pack and install, please.
