Re: Procharger Water Meth / Holley Sniper
[Re: BillR1212]
#2880345
01/26/21 11:09 AM
01/26/21 11:09 AM
Posts: 12,138 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If they are applicable, there are meth injection threads over on Hellcats.org. The one take-away that I got from the posts is that the Hellcat guys don't run meth injection much because they are afraid of a delivery failure resulting in a meltdown. They (along with Dodge) concentrate on bringing in outside air and cooling it with the chiller. Which is basically the A/C system cooling the intercooler. Much more complicated, but considered to be dependable. Then they insulate the blower intake from the heads. Etc, etc, etc.
Can't you at least get ambient temp air to the engine?
Master, again and still
[Re: DaveRS23]
#2880348
01/26/21 11:20 AM
01/26/21 11:20 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
I would ditch the water/meth in favor of an intercooler if IAT is your concern.
[Re: BillR1212]
#2880399
01/26/21 01:23 PM
01/26/21 01:23 PM
Posts: 154 Canada
cuda499
Canada
Thanks Team - I agree that with modern injection systems the water meth is not delivered to all cylinders in a uniform fashion. Mainly because the runners are not designed to transfer a wet mixture being port injection. ( I think). Where as the single plane intake is designed exactly for that... Supercharger store has provided me with all sorts of cooling data, but I'm not seeing that in my own system. (It's where I bought the kit from). I do not have much room in the engine bay. It's an e body Cuda. I'd love an intercooler, but not sure how I can accomplish it, without 5 grand of custom fab work, and making getting to plugs, and belts even more of a pain in the ***. If anyone has a procharger big block e body, that is intercooled. I'll gladly take ideas. I found a few pics online. (my brake booster and master cylinder eat up a lot of real estate for the air cleaner, so fresh air is tough. I cut opened up the fake vents on the hood, but I'm guessing that not too much fresh air is being forced in there.
Then why dont you put direct port water injection like the nitrous guys use........
[Re: 416challenger]
#2880429
01/26/21 02:35 PM
01/26/21 02:35 PM
INTMD8
Lake Villa Il
Looks like plenty of room for an air/air in front of the radiator, or mount an air/water anywhere. If you can do any fab work it wouldn't be expensive.
[Re: 416challenger]
#2880586
01/26/21 07:18 PM
01/26/21 07:18 PM
Posts: 27 Tampa FL
BillR1212
Tampa FL
BillR1212- I am not running a Sniper, but am running a Holley throttle body with multiport ran by HP EFI with Holley's water methanol kit. I have water methanol injection nozzle in the carb hat and it works well. I have had an instance where the injection did not come on and I think I saw similar temps of around 140° F, but typically see high 90s°- 103°F during a 1/4" mile pass. Wow - Those are good temps. Per the supercharger store, I'm running my water/meth before the blower. Should I change it to post blower?
[Re: INTMD8]
#2880587
01/26/21 07:20 PM
01/26/21 07:20 PM
Posts: 27 Tampa FL
BillR1212
Tampa FL
Looks like plenty of room for an air/air in front of the radiator, or mount an air/water anywhere. If you can do any fab work it wouldn't be expensive. You're correct, there is room for air to air, it's just the piping to get it there. I'm not a fabricator sadly. It would likely be an expensive job. In theory the water meth should work for me.
[Re: BillR1212]
#2880606
01/26/21 07:43 PM
01/26/21 07:43 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I have looked into lowering the IAT on my roots blown HEMI. W/M is supposed to be good for 50/60* I went with N2O that comes out of the bottle @ 130* and hope to see 100* decrease in IAT. Supposedly 135* or better is ideal.
[Re: BillR1212]
#2881419
01/28/21 06:05 PM
01/28/21 06:05 PM
Posts: 43,211 Bend,OR USA
Cab_Burge
Any time you compress air you will heat it up, I've seen 130 IAT on a pump gas Roots blown with 7.5 lbs. of boost at 7300 RPM making 924 HP , that motor had a Littlefield 10-71 blower with two carb shop 1050 CFM Dominator blower carbs on it, it was 12% under driven for those tests using 91 octane CA pump swill back in 2001, we switch the pulleys around to get 13% over drive and got 12.0 lbs. of pressure at 6500 RPM making 1027 HP when the motor started going into detonation on 110 octane race gas with 190 F IAT Hot air expands, especially when compressed, and that leans the motor out. Cooling the intake air will make more power based on more air and fuel getting into the motor which will make more power Good luck on this , you can fix it
[Re: BillR1212]
#2881653
01/29/21 11:18 AM
01/29/21 11:18 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I used a Snow kit on a 440-6 car, it worked great, not sure why it wouldn't work on a supercharged car. You can place the nozzles were ever you like, or just use a plate or a combo of both. They make various kit specifically for boosted applications.
[Re: Mr.Yuck]
#2881670
01/29/21 11:56 AM
01/29/21 11:56 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I used a Snow kit on a 440-6 car, it worked great, not sure why it wouldn't work on a supercharged car. You can place the nozzles were ever you like, or just use a plate or a combo of both. They make various kit specifically for boosted applications. Cool....can you post pictures of the nozzle set-up on your 6 pack and install, please.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
