Comp Eng Coil Overs #288027
04/14/09 03:39 AM
04/14/09 03:39 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
when i back halved my car i used the Comp Eng budget coil over kit. it's worked well getting me down to 9.6 but i need to upgrade. Comp Eng also do a 12 pt adjustable rear coil over shock that might be my next step up. anybody use them? do you use the same spring on these or do they have a different spring? bit lost trying to find the right info.
Re: Comp Eng Coil Overs [Re: rebel] #288028
04/14/09 06:07 AM
04/14/09 06:07 AM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
I would get the Strange Double Adjustable coil overs...just my
Re: Comp Eng Coil Overs [Re: rebel] #288029
04/14/09 01:53 PM
04/14/09 01:53 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
...Koni...Strange...Chassisworks Vari-shock....ANYTHING but CE....you get what you pay for
Re: Comp Eng Coil Overs [Re: Chassisman] #288030
04/15/09 02:23 AM
04/15/09 02:23 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
ok so whats wrong with them? their el cheapo 3 way adjustables worked ok for what they were, i'm just wanting to fine tune the car & get it weighed. the 3 way shock kit is too basic to fine tune the weight so i'm looking to find something more adjustable but not mega buck!
Re: Comp Eng Coil Overs [Re: rebel] #288031
04/15/09 06:18 AM
04/15/09 06:18 AM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
I don't consider going from a single adjustable shock to another single adjustable shock with more settings an upgrade...
If you want to fine tune...Double adjustable shocks would be a better choice than a single adjustable shock.
Re: Comp Eng Coil Overs [Re: rebel] #288032
04/15/09 02:21 PM
04/15/09 02:21 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Good shocks don't come cheap but you will definitely tell the difference the second you leave the starting line.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Comp Eng Coil Overs [Re: Irun5snd8th] #288033
04/15/09 11:59 PM
04/15/09 11:59 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
so do QA1's cut it or are they junk as well?
Re: Comp Eng Coil Overs [Re: rebel] #288034
04/16/09 05:59 AM
04/16/09 05:59 AM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
Not junk...But at that point the Strange and Chassisworks Vari-shocks are only a little more....I would still suggest double adjustable over single adj with whatever shock you decide to go with...
Re: Comp Eng Coil Overs [Re: Cudafied] #288035
04/16/09 06:16 AM
04/16/09 06:16 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
What is the absolute best bang for the buck cheap coil over shock out there right now, w/o going to a CE? I know what's best but I need to buy something soon just to get the car done, no money for the best stuff right now.
