crank register adapter #2878293
01/22/21 12:13 PM
01/22/21 12:13 PM
Wi.
old_racer Offline OP
Wi.
a friend has an fuel crank he want's to use , it has no converter register, they use to make a adapter sleeve you could pound in there . anyone have one or know where to get one, I read an old thread where keith black used to sell them , all they have now is a web site with tee shirts and hats, I tried ATI and such but all they have is adapter sleeves for chev trans etc. thanks.
Re: crank register adapter [Re: old_racer] #2878389
01/22/21 02:11 PM
01/22/21 02:11 PM
Call Tim at FHO and maybe Ray Barton scope
I need another two now also, please let us know who and where you find them.
I had one of the old KB adapters left but I can't find it now whiney
Re: crank register adapter [Re: old_racer] #2878401
01/22/21 02:26 PM
01/22/21 02:26 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I have a Keith black 4.25 crank with the same problem
Call Meziere they made me an adapter and flex plate
No one around here could do the register ring for me
Talk to Jerry tell him Ari sent you
He help me alot
1-516-279-0493 if you want to talk Ari
1.39 9.85 - 137 mph
Re: crank register adapter [Re: Ari440] #2878475
01/22/21 04:10 PM
01/22/21 04:10 PM
Wi.
Wi.
thanks for the replys
Re: crank register adapter [Re: old_racer] #2878559
01/22/21 07:04 PM
01/22/21 07:04 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I’m gonna try to do mine on the lathe, I cut one off an old beat up crank.
Re: crank register adapter [Re: cudaman1969] #2878588
01/22/21 08:27 PM
01/22/21 08:27 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
pretty easy to make in a lathe... been there done that
Re: crank register adapter [Re: old_racer] #2878626
01/22/21 09:51 PM
01/22/21 09:51 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
We have one Russ. We ran it with our first combo which had a fueler crank with no converter provision. You must run a 3/8” spacer or mid plate. It works fine. Standard converter. If you can use it let us know
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: crank register adapter [Re: boatracer572] #2878796
01/23/21 10:43 AM
01/23/21 10:43 AM
NC
440Jim Offline
440Jim  Offline
NC
What dimensions and tolerance did you use?
Re: crank register adapter [Re: 440Jim] #2878888
01/23/21 01:37 PM
01/23/21 01:37 PM
Wi.
Wi.
ya my friend has a lathe, he said he'd try and make one .
Re: crank register adapter [Re: 440Jim] #2878902
01/23/21 01:55 PM
01/23/21 01:55 PM
San Jose Ca.
San Jose Ca.
[quote=440Jim][quote=boatracer572]
.0015 press fit in the crank, same tolerance as oem crank on the register to the flywheel, used a piece of 4340
