Hood structure bonding #2878058
01/21/21 08:30 PM
01/21/21 08:30 PM
n h
sawduster Offline OP
n h
69 RR hood. The bonding is gone.
What do I use to re-bond the the hood skin to the under structure?
Thanks in advance.
Re: Hood structure bonding [Re: sawduster] #2878071
01/21/21 09:02 PM
01/21/21 09:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Panel bond. Urethane would also work.
Re: Hood structure bonding [Re: NITROUSN] #2878208
01/22/21 07:30 AM
01/22/21 07:30 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
DON'T USE panel bond to attach the braces to the hood skin.
when panel bond dries it gets rock hard. now your hood flexes and you just made a up dent in your hood.
you need something that stays flexible when it dries. 3M might make something designed for this. i don't have the product chart to look this up on hand, my 3M supplier paint rep has it.
if I were doing this i would use 3M urethane seam sealer.it's available in a couple of different colors, our shop uses gray. we keep this in stock ALL of the time and it works excellent. i have been using this product for at least 15 years without problems. and it's always in stock our shop gets it in what i call sausage packages and uses a special gun. after looking it up i see it's sold in conventional tubes also.
keep in mind it takes a LONG time, a couple of days, for it to fully cure if you apply if thick like you will need in your situation. it will skin over and appear to be dry, but the inner part will still be wet. you try touching it and it will make a mess.
3m Urethane seam sealer.
this product isn't cheap so keep that in mind.
i have seen similar products made by other companies that is usually cheaper than 3M. i have used a few of them. they are similar but thinner than 3M. in your situation it won't matter.
in a pinch as long as the metal is properly prepped you can use windshield urethane also if that is easier for you to get.. this stays flexible when it dries also.
perception is 90% of reality
Re: Hood structure bonding [Re: Mr T2U] #2878276
01/22/21 11:17 AM
01/22/21 11:17 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I second this post. If I had a need for urethane seam sealer for other repairs I would buy that. If not , I would use the windshield urethane.I would also use some folded up sandpaper to prep both sides to remove any loose material before applying.
Re: Hood structure bonding [Re: sawduster] #2878320
01/22/21 12:51 PM
01/22/21 12:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Is it gone completely or loose on one side. Interesting topic that I have often wondered about myself. If completely replacing the bonding material how does one keep the top of the hood flat ?? shruggy beer
Re: Hood structure bonding [Re: sawduster] #2878451
01/22/21 03:46 PM
01/22/21 03:46 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Is hood black and/or insulated in any way, headers, area of country in use, etc? I 'm wonder how much ambient hood temp should be a consideration with the selection of adhesives. I suspect almost all urethane's/epoxies would work, but some might be better based on your conditions.
Re: Hood structure bonding [Re: jcc] #2878521
01/22/21 05:29 PM
01/22/21 05:29 PM
n h
n h
The bonding is just failed in the center section. Im stripping the hood completely. I marked where the original bonding was and took a picture for reference to apply new. Thanks for the responses. BTW anyone have a picture of the underside with the insulation on it?
Re: Hood structure bonding [Re: sawduster] #2878555
01/22/21 06:52 PM
01/22/21 06:52 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The factory used a plastisol adhesive that was cured when it went through the paint booth. Same material that was used to fill in the plug on the Superbirds. I'm not sure if there is an exact replacement for it. I think I'd use seam sealer as an adhesive.
Re: Hood structure bonding [Re: 6PakBee] #2878586
01/22/21 08:17 PM
01/22/21 08:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The sound pad was attached with clips, look for a series of 1/4" +/- holes punched into the bracing.
Real easy if you have the sound pad handy.
Correct pad BTW will be thin & contoured, not the puffy crap some guys use.
Re: Hood structure bonding [Re: topside] #2880472
01/26/21 03:36 PM
01/26/21 03:36 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Many years back, 3M had something called a hood flutter kit. This was an adhesive to repair the broken bond between the sheet metal and the frame. Haven't looked for it in 20 years so not sure if it still exists.
1972 Dodge Challenger
Re: Hood structure bonding [Re: PLUM_72] #2880481
01/26/21 03:50 PM
01/26/21 03:50 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
https://www.lord.com/products-and-solutions/adhesives/fusor-121124-flexible-foam-%28super-fast%29
Re: Hood structure bonding [Re: PLUM_72] #2880571
01/26/21 06:50 PM
01/26/21 06:50 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I have had really good results using silicone adhesive.
Think RTV but with superior bonding properties.
3M Silicone Adhesive Stuff
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Hood structure bonding [Re: hp383] #2880735
01/27/21 01:20 AM
01/27/21 01:20 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
When I called 3m they said to use a product called 3m nvh. He also said if you just have a small area to use plain silicone, never use a panel bond or 2 part seam sealer.
Re: Hood structure bonding [Re: 4406bbl] #2880766
01/27/21 07:48 AM
01/27/21 07:48 AM
Mr T2U Offline
Mr T2U  Offline
silicone would work. but I WOULD NEVER USE IT.
if you ever want to paint it with automotive paint you will get nothing but fish eyes. there are some ways to prevent this, but they add more troubles than what they are worth.
YES latex house paint is use over silicone successfully. but i don't use house paint on cars.
Re: Hood structure bonding [Re: Mr T2U] #2880880
01/27/21 01:31 PM
01/27/21 01:31 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
[quote=Mr T2U]silicone would work. but I WOULD NEVER USE IT.
Good point, nvh paints nice I can confirm that.
