Re: Hood structure bonding
[Re: NITROUSN]
#2878208
01/22/21 07:30 AM
01/22/21 07:30 AM
Posts: 4,920 new berlin wisconsin
Mr T2U
DON'T USE panel bond to attach the braces to the hood skin. when panel bond dries it gets rock hard. now your hood flexes and you just made a up dent in your hood. you need something that stays flexible when it dries. 3M might make something designed for this. i don't have the product chart to look this up on hand, my 3M supplier paint rep has it. if I were doing this i would use 3M urethane seam sealer.it's available in a couple of different colors, our shop uses gray. we keep this in stock ALL of the time and it works excellent. i have been using this product for at least 15 years without problems. and it's always in stock our shop gets it in what i call sausage packages and uses a special gun. after looking it up i see it's sold in conventional tubes also. keep in mind it takes a LONG time, a couple of days, for it to fully cure if you apply if thick like you will need in your situation. it will skin over and appear to be dry, but the inner part will still be wet. you try touching it and it will make a mess. 3m Urethane seam sealer.this product isn't cheap so keep that in mind. i have seen similar products made by other companies that is usually cheaper than 3M. i have used a few of them. they are similar but thinner than 3M. in your situation it won't matter. in a pinch as long as the metal is properly prepped you can use windshield urethane also if that is easier for you to get.. this stays flexible when it dries also.
perception is 90% of reality
[Re: Mr T2U]
#2878276
01/22/21 11:17 AM
01/22/21 11:17 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
DON'T USE panel bond to attach the braces to the hood skin. when panel bond dries it gets rock hard. now your hood flexes and you just made a up dent in your hood. you need something that stays flexible when it dries. 3M might make something designed for this. i don't have the product chart to look this up on hand, my 3M supplier paint rep has it. if I were doing this i would use 3M urethane seam sealer.it's available in a couple of different colors, our shop uses gray. we keep this in stock ALL of the time and it works excellent. i have been using this product for at least 15 years without problems. and it's always in stock our shop gets it in what i call sausage packages and uses a special gun. after looking it up i see it's sold in conventional tubes also. keep in mind it takes a LONG time, a couple of days, for it to fully cure if you apply if thick like you will need in your situation. it will skin over and appear to be dry, but the inner part will still be wet. you try touching it and it will make a mess. 3m Urethane seam sealer.this product isn't cheap so keep that in mind. i have seen similar products made by other companies that is usually cheaper than 3M. i have used a few of them. they are similar but thinner than 3M. in your situation it won't matter. in a pinch as long as the metal is properly prepped you can use windshield urethane also if that is easier for you to get.. this stays flexible when it dries also. I second this post. If I had a need for urethane seam sealer for other repairs I would buy that. If not , I would use the windshield urethane.I would also use some folded up sandpaper to prep both sides to remove any loose material before applying.
[Re: sawduster]
#2878451
01/22/21 03:46 PM
01/22/21 03:46 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Is hood black and/or insulated in any way, headers, area of country in use, etc? I 'm wonder how much ambient hood temp should be a consideration with the selection of adhesives. I suspect almost all urethane's/epoxies would work, but some might be better based on your conditions.
[Re: sawduster]
#2878555
01/22/21 06:52 PM
01/22/21 06:52 PM
Posts: 10,714 North Dakota
6PakBee
North Dakota
The factory used a plastisol adhesive that was cured when it went through the paint booth. Same material that was used to fill in the plug on the Superbirds. I'm not sure if there is an exact replacement for it. I think I'd use seam sealer as an adhesive.
[Re: topside]
#2880472
01/26/21 03:36 PM
01/26/21 03:36 PM
Posts: 1,232 Chicago, IL
PLUM_72
Chicago, IL
Many years back, 3M had something called a hood flutter kit. This was an adhesive to repair the broken bond between the sheet metal and the frame. Haven't looked for it in 20 years so not sure if it still exists.
1972 Dodge Challenger
[Re: PLUM_72]
#2880481
01/26/21 03:50 PM
01/26/21 03:50 PM
PLUM_72
Chicago, IL
https://www.lord.com/products-and-solutions/adhesives/fusor-121124-flexible-foam-%28super-fast%29
[Re: PLUM_72]
#2880571
01/26/21 06:50 PM
01/26/21 06:50 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I have had really good results using silicone adhesive. Think RTV but with superior bonding properties. 3M Silicone Adhesive Stuff
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: 4406bbl]
#2880766
01/27/21 07:48 AM
01/27/21 07:48 AM
Mr T2U
silicone would work. but I WOULD NEVER USE IT. if you ever want to paint it with automotive paint you will get nothing but fish eyes. there are some ways to prevent this, but they add more troubles than what they are worth. YES latex house paint is use over silicone successfully. but i don't use house paint on cars.
