Front shock lower rubber bushing needed - 71 Barracuda #287755
04/13/09 08:46 PM
04/13/09 08:46 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
I just noticed I'm missing the rubber bushing on the lower end of my front shock where it mounts to the LCA. The shop moved my upper shock mounts out 3/4 inch when they were painting the engine compartment. My guess is they misplaced or forgot it. But its been many months so they wont have it. Local Autozone has a 5/8 id x 1 7/16 poly bushing set, but I don't know if it'll fit. Anyone have one they can measure, or one they don't need?
Re: Front shock lower rubber bushing needed - 71 Barracuda *DELETED* [Re: Vert] #287756
04/14/09 08:29 AM
04/14/09 08:29 AM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Post deleted by Vert
Re: Front shock lower rubber bushing needed - 71 Barracuda [Re: Vert] #287757
04/14/09 08:19 PM
04/14/09 08:19 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
btt for tonights crowd
Re: Front shock lower rubber bushing needed - 71 Barracuda [Re: Vert] #287758
04/14/09 08:24 PM
04/14/09 08:24 PM
Hannibal, MO
gtx_gts1969 Offline
super gas
gtx_gts1969  Offline
super gas
Hannibal, MO
How's my old car doing?
-------------------------------------------- 1966 Dodge D100 short wide bed / 318 / 3spd Retired US Air Force MSgt (E-7)
Re: Front shock lower rubber bushing needed - 71 Barracuda [Re: gtx_gts1969] #287759
04/14/09 09:38 PM
04/14/09 09:38 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Its awakening after a long sleep. Big, loud, and strong. Gotta work out the squeaks, rattles, buzzes, and clatter. Not easy over the valve train clatter and 2 1/2 inch TTi mufflers at 1500 rpm.
Re: Front shock lower rubber bushing needed - 71 Barracuda [Re: Vert] #287760
04/16/09 09:10 PM
04/16/09 09:10 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
One of you guys has to have a set of shocks hanging in the garage. I just need a could of numbers ...
Re: Front shock lower rubber bushing needed - 71 Barracuda [Re: Vert] #287761
04/16/09 09:22 PM
04/16/09 09:22 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
BUSHING, Front Shock, Lower Mounting
P/N 1635588
Re: Front shock lower rubber bushing needed - 71 Barracuda [Re: Snoopy] #287762
04/17/09 08:24 AM
04/17/09 08:24 AM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Snoopy! Thanks! Guess I can order one without wondering if it'll fit. The local parts stores have poly pieces that are 5/16 id x 1 7/16 but I didn't want to grab them unless I knew they'd fit.
Thanks again.
Re: Front shock lower rubber bushing needed - 71 Barracuda [Re: Snoopy] #287763
04/17/09 11:24 AM
04/17/09 11:24 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
P/N 1635588
1635588 is NS1 = no longer avail from mopar
Unless it's rebuilding original hyd shocks, why not just replace the shock?
