Re: Webers on a blower?
[Re: Blucuda413]
#2876636
01/19/21 03:13 PM
01/19/21 03:13 PM
Posts: 4,210 New York
polyspheric
New York
Draw through (above the blower), or blow through (carburetors on the engine)?
Boffin Emeritus
[Re: polyspheric]
#2876644
01/19/21 03:23 PM
01/19/21 03:23 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
Draw through (above the blower), or blow through (carburetors on the engine)? it is going to be awfully hard to blow through any carb with a Roots type supercharger, correct? ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#2876724
01/19/21 04:56 PM
01/19/21 04:56 PM
polyspheric
New York
IMHO yes, just wanted clarity. If draw through, it can idle on 1 bbl. and synchronization isn't needed.
Boffin Emeritus
[Re: Blucuda413]
#2876727
01/19/21 04:57 PM
01/19/21 04:57 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I remember hearing that the IDS is a better carb than the IDA for blower use. The IDS has a high speed enrichment circuit where the IDA tends to go lean at high rpm...could be death with a blower.
[Re: polyspheric]
#2877119
01/20/21 11:36 AM
01/20/21 11:36 AM
Posts: 22,724 Bitopia
jcc
Bitopia
IMHO yes, just wanted clarity. If draw through, it can idle on 1 bbl. and synchronization isn't needed. Yea, I waiting for an explanation on the implied importance of carb sync in this application. maybe just an oversight?
[Re: hemi-itis]
#2877133
01/20/21 12:00 PM
01/20/21 12:00 PM
John_Kunkel
Rio Linda, CA
What is the total CFM of these carbs and what is the intended use? That's the neat thing about Webers, they have a removable "choke" (venturi), allowing it to be instantly converted from a large-CFM carburetor to one of small CFM, or vice-versa. The basic carb number (48) is the throttle blade diameter in millimeters.
[Re: Blucuda413]
#2877143
01/20/21 12:14 PM
01/20/21 12:14 PM
polyspheric
New York
The internal tuning parts are going to be $$$$$
Boffin Emeritus
[Re: Blucuda413]
#2877251
01/20/21 01:55 PM
01/20/21 01:55 PM
jcc
Bitopia
This is way above my pay grade, but isn't this blower (rotating Roots) more partial to some side to side differential airflow anyway, and likely changes that un-evenness based on the RPM?
[Re: jcc]
#2877282
01/20/21 02:22 PM
01/20/21 02:22 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
We need pictures of this rig!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Blucuda413]
#2877531
01/20/21 08:56 PM
01/20/21 08:56 PM
polyspheric
New York
Synchronized vs. sequential vs. progressive makes no difference. All of the mixture is going to the same place regardless of which/how many carburetors are open how much: the extreme front of the rotors, just behind the drive gears. Very little reaches the rear 4 cylinders.
Maybe it was removed because no one knew how to jet them?
Boffin Emeritus
[Re: Blucuda413]
#2877560
01/20/21 09:35 PM
01/20/21 09:35 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
What is the intended use?? Street or drag? My un-experienced (webber wise) would be cool conversation generator at a car show/cruise nite... PIA in competition conditions.Not saying don't think out side the box but if these were worth anything but conversation starters they would be more prevalent at the track. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) They would look cool on an old Gasser/Nostalgia drag car that's for sure!
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
