Webers on a blower? #2876497
01/19/21 11:41 AM
01/19/21 11:41 AM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
Anyone have any experience using 4 Weber 48IDA carbs on a 6/8-71? I've just procured a complete setup for a blower. Unit has been sitting for years and since I have zero experience with these carbs I'm asking input from those with experience. Unit has manifold to blower, 4 48IDA carbs (Italy), fuel line plumbed and all linkage. How should I proceed from the start. Unit will be installed on a 413ci SBM setup with a 6-71. Suggestions appreciated!!
Re: Webers on a blower? [Re: Blucuda413] #2876543
01/19/21 01:16 PM
01/19/21 01:16 PM
AndyF Offline
AndyF  Offline
Well it will look cool and if you have the linkage properly synchronized it should run pretty good. There are lots of books and articles on Weber carbs so dig in and do some research. They have a lot of tuning capability but you'll need to source some parts. The linkage is very critical. All 8 throttles have to be synchronized or else it will never run very well. I've worked on them just enough to know what a pain the linkage is. Hopefully your setup came with a well designed linkage. Take a close look at it and see if operates freely with all four carbs closed at idle and WOT at the same time.
Re: Webers on a blower? [Re: Blucuda413] #2876636
01/19/21 03:13 PM
01/19/21 03:13 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Draw through (above the blower), or blow through (carburetors on the engine)?
Boffin Emeritus
Re: Webers on a blower? [Re: polyspheric] #2876644
01/19/21 03:23 PM
01/19/21 03:23 PM
it is going to be awfully hard to blow through any carb with a Roots type supercharger, correct? work
Re: Webers on a blower? [Re: Cab_Burge] #2876724
01/19/21 04:56 PM
01/19/21 04:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
IMHO yes, just wanted clarity.
If draw through, it can idle on 1 bbl. and synchronization isn't needed.
Boffin Emeritus
Re: Webers on a blower? [Re: Blucuda413] #2876727
01/19/21 04:57 PM
01/19/21 04:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I remember hearing that the IDS is a better carb than the IDA for blower use. The IDS has a high speed enrichment circuit where the IDA tends to go lean at high rpm...could be death with a blower.
Re: Webers on a blower? [Re: John_Kunkel] #2877067
01/20/21 10:16 AM
01/20/21 10:16 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What is the total CFM of these carbs and what is the intended use?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Webers on a blower? [Re: polyspheric] #2877119
01/20/21 11:36 AM
01/20/21 11:36 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yea, I waiting for an explanation on the implied importance of carb sync in this application. maybe just an oversight?
Re: Webers on a blower? [Re: hemi-itis] #2877133
01/20/21 12:00 PM
01/20/21 12:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's the neat thing about Webers, they have a removable "choke" (venturi), allowing it to be instantly converted from a large-CFM carburetor to one of small CFM, or vice-versa. The basic carb number (48) is the throttle blade diameter in millimeters.
Re: Webers on a blower? [Re: Blucuda413] #2877143
01/20/21 12:14 PM
01/20/21 12:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The internal tuning parts are going to be $$$$$
Boffin Emeritus
Re: Webers on a blower? [Re: polyspheric] #2877212
01/20/21 01:19 PM
01/20/21 01:19 PM
Alexandria, LA
Alexandria, LA
Thanks for the inputs and comments, on some forums I'm getting nothing. This setup was on a Hemi/8-71, don't know what type or size of hemi and it has been sitting for many years. I haven't started cleaning it as yet but hopefully I will find something that leads me to who built it. It looks extremely well built with linkage and gas line components like the new 4 Weber systems have. I don't know cfm but if built correctly for a hemi it should be ok for my 413 sbm which I built for a blower. The setup is going on a race car but I don't know if it will ever hit the track, if it does I'll have to find a driver. I have some experience with multicarb setups I use to run 6 carbs on my sbc in the 50s and early 60s. I believe most people have syncing problems when running these carbs on IR manifolds. In this case since the manifold and blower both are plenums I wouldn't think syncing would be as great a problem. I've certainly noticed that the individual parts are expensive and I hope I won't need many but when needed I'll just have to search until I can find something I can afford. I've always loved the looks of these systems and when this one popped up I just couldn't refuse. This setup has long stacks on the carbs so it will be like the old AFX cars with 8 tall fi stacks sticking thru the hood.
Re: Webers on a blower? [Re: Blucuda413] #2877251
01/20/21 01:55 PM
01/20/21 01:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
This is way above my pay grade, but isn't this blower (rotating Roots) more partial to some side to side differential airflow anyway, and likely changes that un-evenness based on the RPM?
Re: Webers on a blower? [Re: jcc] #2877282
01/20/21 02:22 PM
01/20/21 02:22 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
We need pictures of this rig!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Webers on a blower? [Re: Hemi_Joel] #2877303
01/20/21 02:44 PM
01/20/21 02:44 PM
moparx Online content
moparx  Online Content
OH YEAH ! drool
beer
Re: Webers on a blower? [Re: Blucuda413] #2877324
01/20/21 03:07 PM
01/20/21 03:07 PM
AndyF Offline
AndyF  Offline
Post some pictures if you get a chance. The linkage is the critical part. If the linkage works properly so all four carbs have the same throttle position for full travel then you should be able to get it to work. Dialing in the tune might be a job for an expert.
Re: Webers on a blower? [Re: Blucuda413] #2877531
01/20/21 08:56 PM
01/20/21 08:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Synchronized vs. sequential vs. progressive makes no difference.
All of the mixture is going to the same place regardless of which/how many carburetors are open how much: the extreme front of the rotors, just behind the drive gears. Very little reaches the rear 4 cylinders.
Maybe it was removed because no one knew how to jet them?
Boffin Emeritus
Re: Webers on a blower? [Re: polyspheric] #2877550
01/20/21 09:19 PM
01/20/21 09:19 PM
Alexandria, LA
Alexandria, LA
You could certainly be correct. The young man I bought them from said they were his father's and he didn't even know the last time they were used. His father sold the hemi and the buyer did not want the Webers. Who knows he was selling.
Re: Webers on a blower? [Re: Blucuda413] #2877560
01/20/21 09:35 PM
01/20/21 09:35 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
What is the intended use?? Street or drag? My un-experienced (webber wise) would be cool conversation generator at a car show/cruise nite... PIA in competition conditions.Not saying don't think out side the box but if these were worth anything but conversation starters they would be more prevalent at the track. twocents They would look cool on an old Gasser/Nostalgia drag car that's for sure!
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Webers on a blower? [Re: W.I.N. Racing] #2877602
01/20/21 11:28 PM
01/20/21 11:28 PM
hemi-itis Offline
hemi-itis  Offline
Next best thing to a roots hanging out your hood if you wear one! up
Re: Webers on a blower? [Re: Blucuda413] #2877607
01/20/21 11:38 PM
01/20/21 11:38 PM
AndyF Offline
AndyF  Offline
Obviously home made and looks like a street rod setup rather than a serious race piece. If you plan on running that setup you should find someone who knows how to rebuild those carbs. It would be good to test each carb before trying to fire up a blown engine with that setup on top.
