Re: NP 435 question
[Re: blaze]
#2875696
01/17/21 07:14 PM
01/17/21 07:14 PM
Posts: 5,945 ohio
ruderunner
ohio
Look at the backside, there's probably a groove in the casting, I bet about 38 inch wide by maybe 34 inch long. Its an oil return passage.
It should line up with an unthreaded hole in the case around the bearing.
Don't forget some thread sealer on the bolts, pretty sure they go through the casting.
Angry white pureblood male
Re: NP 435 question
[Re: ruderunner]
#2875811
01/17/21 11:12 PM
01/17/21 11:12 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Don't forget some thread sealer on the bolts, pretty sure they go through the casting. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Yep just line up the hole in the case with the machined groove in the retainer and gasket. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
