Page 1 of 3 1 2 3
trashed another rear, what rear to use now? 489,742,741 #287498
04/13/09 07:14 PM
04/13/09 07:14 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I tore up another rear. the pin that runs throught the posi unit came out and ran into the pinion gear and destroyed it. it was the type of posi without the clutch disc in it. this is the 3rd time this type of posi has came apart on me like this. all different cars but same type of posi. the clutch type has never came apart on me like this.
is this type of posi unit just not as strong? I have all of the 3 types of cases,741,742,and 489 and i want to build a unit to hold up to my driving. I also have a couple of the clutch style posi units that worked when i puled them out of the cars they were in.
I am running a dart with a edelbrock head 360,9.5-1 pistons,488 cam. in it with a 4 speed.the rear is quarter tubbed to fit n50 15 mickey thompsons on it.and i was wanting to run it on street nite at the strip.
what case would be best to use? also what one of the posi units is stronger? i will be running 4.30 gears.
also what brand of parts would you recomend?
thanks.
Post deleted by Defbob [Re: dirt] #287499
04/13/09 07:15 PM
04/13/09 07:15 PM
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287500
04/13/09 07:17 PM
04/13/09 07:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
83/4s are bullet proof, what are you talking about? keep rebuilding them
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287501
04/13/09 07:17 PM
04/13/09 07:17 PM
Renton Washington
Triple Threat Offline
Renton Washington
Seeing as you have torn up a couple 8 3/4 centers now, it might be time to look towards a dana. I know your combo isn't making tons of power, but the 4 speed is hard on parts.
If your going to stay with the 8 3/4 , either the 489 or 742 should be your next test ....
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: trashed another rear, what rear to use now? 489,742,741 [Re: Quicktree] #287502
04/13/09 07:46 PM
04/13/09 07:46 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
100% (LOL)!!!
Re: trashed another rear, what rear to use now? 489,742,741 [Re: actionange] #287503
04/13/09 07:52 PM
04/13/09 07:52 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
a dana isint in the budget right now. its either fix the 8 3/4 or let it sit broken.
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287504
04/13/09 08:02 PM
04/13/09 08:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ll sell you mine. Joke; I use the 742 case and so far it`s holding up but, time will tell. I will eventually get the alum. center section and lighten the car but it`s what`s in it now so I run it. I agree 4-speeds kill stuff.
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287505
04/13/09 08:04 PM
04/13/09 08:04 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Just put a spool in it
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: trashed another rear, what rear to use now? 489,742,741 [Re: hemi-itis] #287506
04/13/09 08:15 PM
04/13/09 08:15 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
It's a cone pos..Junk! should never been in your car...buy a good one chutch type ..or a spool
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287507
04/13/09 08:23 PM
04/13/09 08:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You keep breaking posi units, not the diff or gears.
The cone unit is sorta weak so use the clutch type
or go to a spool and the spool would be cheaper but
harder on the street(cornering)
Re: trashed another rear, what rear to use now? 489,742,741 [Re: MR_P_BODY] #287508
04/13/09 08:51 PM
04/13/09 08:51 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i have a couple of the clutch type. i could rebuild them and use if they are stronger.I figured the cone type must be junk. i had the clutch type in my dart for 10 years and never tore it up. are they hard to rebuild? i always just used them the way they were
Re: trashed another rear, what rear to use now? 489,742,741 [Re: hemi-itis] #287509
04/13/09 08:53 PM
04/13/09 08:53 PM
wappinger falls new york
Jimi_Vignogna Offline
that is like saying just put two dominators on a blown hemi
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287510
04/13/09 08:54 PM
04/13/09 08:54 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I think I still have some new clutchs..if you was closer I show you to rebuild them..I ran one one the coronet for years..ran 8.00-7.70 in the 1/8 with one never hurt it.
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287511
04/13/09 09:38 PM
04/13/09 09:38 PM
an8sec70cuda Offline
Get a spool, cheap and strong. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287512
04/13/09 10:11 PM
04/13/09 10:11 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
like said above, avoid the cone junk. Between the clutch stuff that you already have you could probably come up with enough good clutches for one unit. If one of them has one piece side gears use those. Here is the clutch arrangement in the pic. All info is in the factory service manual but in a nutshell for swapping differentials, adjust gears to zero lash, tighten adjuster that is NOT on the ring gear side to achieve .006-.008" backlash (along with correct diff bearing preload)
Re: trashed another rear, what rear to use now? 489,742,741 [Re: an8sec70cuda] #287513
04/13/09 10:19 PM
04/13/09 10:19 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
got to agree with that too. Each of those clutch sure grip are worth at least twice as much as one of those $100 ebay spools.
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287514
04/13/09 10:32 PM
04/13/09 10:32 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
you did,nt say what case you have, 489, ect. I suppose you have a 489 case, cone clutch, with a factory crush sleeve? That is the problem with them. Let us know all the info.
Engine by DeTar http://www.kansasbadman.com
Re: trashed another rear, what rear to use now? 489,742,741 #287515
04/13/09 10:45 PM
04/13/09 10:45 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
forget the 83/4 get a dana
Jeez', It's a 9.5:1 360 with a hydraulic cam for God's sake...and it didn't even break the ring gear or axle shaft, it broke a posi.
"Get a Dana"
Re: trashed another rear, what rear to use now? 489,742,741 [Re: VernMotor] #287516
04/13/09 10:50 PM
04/13/09 10:50 PM
your flying now, you go vern!!!
Re: trashed another rear, what rear to use now? 489,742,741 [Re: dirt] #287517
04/13/09 10:54 PM
04/13/09 10:54 PM
Let it sit until you can afford a GOOD Dana, small blocks with 4 speeds kill 8 3/4 eventually every time you race them, street or strip In fact any 4 speed Mopar that is raced on the street or strip will break the 8 3/4 eventually if it makes any power and hooks up at all Huh, Quicktree
Page 1 of 3 1 2 3
