trashed another rear, what rear to use now? 489,742,741
#287498
04/13/09 07:14 PM
04/13/09 07:14 PM
Posts: 1,349 warfordsburg, PA
dirt
warfordsburg, PA
I tore up another rear. the pin that runs throught the posi unit came out and ran into the pinion gear and destroyed it. it was the type of posi without the clutch disc in it. this is the 3rd time this type of posi has came apart on me like this. all different cars but same type of posi. the clutch type has never came apart on me like this. is this type of posi unit just not as strong? I have all of the 3 types of cases,741,742,and 489 and i want to build a unit to hold up to my driving. I also have a couple of the clutch style posi units that worked when i puled them out of the cars they were in. I am running a dart with a edelbrock head 360,9.5-1 pistons,488 cam. in it with a 4 speed.the rear is quarter tubbed to fit n50 15 mickey thompsons on it.and i was wanting to run it on street nite at the strip. what case would be best to use? also what one of the posi units is stronger? i will be running 4.30 gears. also what brand of parts would you recomend? thanks.
Post deleted by Defbob
[Re: dirt]
#287499
04/13/09 07:15 PM
04/13/09 07:15 PM
Re: trashed another rear, what rear to use now? 489,742,741
[Re: dirt]
#287501
04/13/09 07:17 PM
04/13/09 07:17 PM
Triple Threat
Renton Washington
Seeing as you have torn up a couple 8 3/4 centers now, it might be time to look towards a dana. I know your combo isn't making tons of power, but the 4 speed is hard on parts.
If your going to stay with the 8 3/4 , either the 489 or 742 should be your next test ....
[Re: Quicktree]
#287502
04/13/09 07:46 PM
04/13/09 07:46 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
83/4s are bullet proof, what are you talking about? keep rebuilding them
100% (LOL)!!!
[Re: dirt]
#287504
04/13/09 08:02 PM
04/13/09 08:02 PM
Thumperdart
State of confusion
I`ll sell you mine. Joke; I use the 742 case and so far it`s holding up but, time will tell. I will eventually get the alum. center section and lighten the car but it`s what`s in it now so I run it. I agree 4-speeds kill stuff.
[Re: dirt]
#287507
04/13/09 08:23 PM
04/13/09 08:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You keep breaking posi units, not the diff or gears. The cone unit is sorta weak so use the clutch type or go to a spool and the spool would be cheaper but harder on the street(cornering)
[Re: dirt]
#287511
04/13/09 09:38 PM
04/13/09 09:38 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Get a spool, cheap and strong. CHIP
[Re: dirt]
#287512
04/13/09 10:11 PM
04/13/09 10:11 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
like said above, avoid the cone junk. Between the clutch stuff that you already have you could probably come up with enough good clutches for one unit. If one of them has one piece side gears use those. Here is the clutch arrangement in the pic. All info is in the factory service manual but in a nutshell for swapping differentials, adjust gears to zero lash, tighten adjuster that is NOT on the ring gear side to achieve .006-.008" backlash (along with correct diff bearing preload)
[Re: an8sec70cuda]
#287513
04/13/09 10:19 PM
04/13/09 10:19 PM
446acuda
Charlotte, NC
got to agree with that too. Each of those clutch sure grip are worth at least twice as much as one of those $100 ebay spools.
[Re: dirt]
#287514
04/13/09 10:32 PM
04/13/09 10:32 PM
Posts: 1,074 Wichita Kansas
CH3NO2
Wichita Kansas
you did,nt say what case you have, 489, ect. I suppose you have a 489 case, cone clutch, with a factory crush sleeve? That is the problem with them. Let us know all the info.
#287515
04/13/09 10:45 PM
04/13/09 10:45 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
forget the 83/4 get a dana
Jeez', It's a 9.5:1 360 with a hydraulic cam for God's sake...and it didn't even break the ring gear or axle shaft, it broke a posi.
"Get a Dana"
[Re: VernMotor]
#287516
04/13/09 10:50 PM
04/13/09 10:50 PM
I think I still have some new clutchs..if you was closer I show you to rebuild them..I ran one one the coronet for years..ran 8.00-7.70 in the 1/8 with one never hurt it.
your flying now, you go vern!!!
[Re: dirt]
#287517
04/13/09 10:54 PM
04/13/09 10:54 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
a dana isint in the budget right now. its either fix the 8 3/4 or let it sit broken.
Let it sit until you can afford a GOOD Dana, small blocks with 4 speeds kill 8 3/4 eventually every time you race them, street or strip In fact any 4 speed Mopar that is raced on the street or strip will break the 8 3/4 eventually if it makes any power and hooks up at all Huh, Quicktree
