What manifold dates on an A12.... #287039
04/13/09 11:33 AM
04/13/09 11:33 AM
MO
cdp Offline OP
cdp  Offline OP
MO
A friend has some 69 manifolds that he said he'd trade even for another set, regardless of date.
What date code should I be looking for? I think he said these were 4-69.
thanks
Chris
Re: What manifold dates on an A12.... [Re: cdp] #287040
04/13/09 12:50 PM
04/13/09 12:50 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
What's your cars scheduled production date ?
logan426
Re: What manifold dates on an A12.... [Re: MLR426] #287041
04/13/09 01:11 PM
04/13/09 01:11 PM
MO
cdp Offline OP
cdp  Offline OP
MO
its a 426 date. here is the tag....
Re: What manifold dates on an A12.... [Re: cdp] #287042
04/13/09 01:25 PM
04/13/09 01:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can't go by the tag date on an A12 as they were built well into June of 69 with all tags of the second run reading 4/26 .
Whats the assembly date of your engine ?
Re: What manifold dates on an A12.... [Re: cdp] #287043
04/13/09 01:26 PM
04/13/09 01:26 PM
Buffalo, NY U.S.A.
MrNormsTA Offline
MrNormsTA  Offline
Buffalo, NY U.S.A.
A 283xxx I would think would be an April/May build. A 4/69 would be fine, but as John said do you have a date on the k frame or motor which is a good reference date.
Rick.
Re: What manifold dates on an A12.... [Re: MrNormsTA] #287044
04/13/09 01:39 PM
04/13/09 01:39 PM
MO
cdp Offline OP
cdp  Offline OP
MO
My car is an all #'s car, but I never paid attention to the dates on the Kmember, engine block, etc.
My block cast is 5-15-69, so I should be good to go.
How do I find the engine assembly date?
The major components missing were the exhaust manifolds, distributor and H-Wheels.
All I need now is a distributor or tag.
Re: What manifold dates on an A12.... [Re: cdp] #287045
04/13/09 01:43 PM
04/13/09 01:43 PM
Buffalo, NY U.S.A.
MrNormsTA Offline
MrNormsTA  Offline
Buffalo, NY U.S.A.
Top pad where it should say HP or HP2 should also be a month and day stamp.
Re: What manifold dates on an A12.... [Re: cdp] #287046
04/13/09 01:43 PM
04/13/09 01:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Assembly date is on the engine ID tag , I'm curious to see what it is compared to your casting date .
Re: What manifold dates on an A12.... [Re: JohnRR] #287047
04/13/09 02:37 PM
04/13/09 02:37 PM
The Last Frontier
Alaska_A12 Offline
Alaska_A12  Offline
The Last Frontier
It seems to be generally accepted that the K-member stamped date is very close to production date. My 280xxx Roadrunner's K-frame was stamped 155 for June 4th. Your engine cast date timing doesn't help much because there can be quite a lag from the date the block is cast and the engine actually assembled.
The K-frame number is not hard to find. It's generally front and center viewed from below. It will also have a 9 and a 1 or 2 for shift that built it.
______________________________________________ http://regcars.homestead.com/car107.html
Re: What manifold dates on an A12.... [Re: Alaska_A12] #287048
04/13/09 03:20 PM
04/13/09 03:20 PM
PA
P
PLATINUM6BBL Offline
P
PA
my A12 was around 5/30 build date, according to Galen and its' vin number is less than 100 after yours
1969-1/2 A12 LOH Road Runner A4 w/ M6S
13.34 at 104 PSMCDR 9/06 in Mopar Action 8/07
12.95 at 105.94 F.A.S.T. 11/06
Re: What manifold dates on an A12.... [Re: PLATINUM6BBL] #287049
04/13/09 04:43 PM
04/13/09 04:43 PM
MO
cdp Offline OP
cdp  Offline OP
MO
My motor build date is 5-28-69.
I picked up the manifolds and they are 2-28-69. Maybe a bit too early, but they'll work for me.
Re: What manifold dates on an A12.... [Re: cdp] #287050
04/13/09 05:27 PM
04/13/09 05:27 PM
MO
cdp Offline OP
cdp  Offline OP
MO
6bblGT had the build sheet that was the car right before mine. I'd love to see the info.
Unfortunatley, the original owner threw away the original window sticker/paperwork after their divorce. Luckily I have the original title, but no build sheet.
Re: What manifold dates on an A12.... [Re: cdp] #287051
04/13/09 10:34 PM
04/13/09 10:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Sometimes I need a reminder. Check your mail .... looks like your car was built first.
Why hasn't anyone mentioned "IT"? ..... Look NO PAINT!!
Re: What manifold dates on an A12.... [Re: 6bblgt] #287052
04/13/09 11:58 PM
04/13/09 11:58 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
ah sorry I've been on vacation with the family and I'm on a new kick lately "Not Bent" or creased in the upper left corner on those Lynch Road tags, paint optional.....
MikeR
agree with the late May+ possible build date with that VIN, my A12 with a 270xxx VIN is a May 7-9 assembly as close as I know...
Re: What manifold dates on an A12.... [Re: A12] #287053
04/14/09 02:31 AM
04/14/09 02:31 AM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
My engine was cast 05-15-69, assembled 06-04-69, vin 272929. Exhaust manifolds are dated 05-23 and 05-25. Car was probably built during the 2nd or 3rd weeks of June. The door panels are also dated in the 05-23 range. It has been a while since I had it apart and didn't record dates from the panels.
dstryr, since 1986.
Re: What manifold dates on an A12.... [Re: dstryr] #287054
04/14/09 08:51 AM
04/14/09 08:51 AM
sixbbl69 Offline
sixbbl69  Offline
take all the date codes on your car go back 6 months and forward till June when they stopped making these cars and you will be safe with parts. unless you bought your car new its only a guess anyway .
Re: What manifold dates on an A12.... [Re: sixbbl69] #287055
04/14/09 02:29 PM
04/14/09 02:29 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
even then can an original owner prove that nothing was ever changed?
dstryr, since 1986.
Re: What manifold dates on an A12.... [Re: dstryr] #287056
04/14/09 03:41 PM
04/14/09 03:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: What manifold dates on an A12.... [Re: JohnRR] #287057
04/14/09 03:44 PM
04/14/09 03:44 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Im sure ol dilweeds car is perfect, at least his record for being a troll is.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: What manifold dates on an A12.... [Re: dstryr] #287058
04/14/09 11:43 PM
04/14/09 11:43 PM
sixbbl69 Offline
sixbbl69  Offline
Only if you believe him.
