Re: What manifold dates on an A12....
[Re: cdp]
#287043
04/13/09 01:26 PM
04/13/09 01:26 PM
Posts: 6,519 Buffalo, NY U.S.A.
MrNormsTA
Buffalo, NY U.S.A.
A 283xxx I would think would be an April/May build. A 4/69 would be fine, but as John said do you have a date on the k frame or motor which is a good reference date.
Rick.
[Re: cdp]
#287046
04/13/09 01:43 PM
04/13/09 01:43 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
My car is an all #'s car, but I never paid attention to the dates on the Kmember, engine block, etc.
My block cast is 5-15-69, so I should be good to go.
How do I find the engine assembly date?
The major components missing were the exhaust manifolds, distributor and H-Wheels.
All I need now is a distributor or tag.
Assembly date is on the engine ID tag , I'm curious to see what it is compared to your casting date .
[Re: Alaska_A12]
#287048
04/13/09 03:20 PM
04/13/09 03:20 PM
Posts: 3,427 PA
PLATINUM6BBL
PA
my A12 was around 5/30 build date, according to Galen and its' vin number is less than 100 after yours
1969-1/2 A12 LOH Road Runner A4 w/ M6S 13.34 at 104 PSMCDR 9/06 in Mopar Action 8/07 12.95 at 105.94 F.A.S.T. 11/06
[Re: 6bblgt]
#287052
04/13/09 11:58 PM
04/13/09 11:58 PM
Posts: 21,505 N.E. OHIO, USA
A12
N.E. OHIO, USA
Why hasn't anyone mentioned "IT"? ..... Look NO PAINT!!
ah sorry I've been on vacation with the family and I'm on a new kick lately "Not Bent" or creased in the upper left corner on those Lynch Road tags, paint optional.....
MikeR
agree with the late May+ possible build date with that VIN, my A12 with a 270xxx VIN is a May 7-9 assembly as close as I know...
[Re: A12]
#287053
04/14/09 02:31 AM
04/14/09 02:31 AM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
My engine was cast 05-15-69, assembled 06-04-69, vin 272929. Exhaust manifolds are dated 05-23 and 05-25. Car was probably built during the 2nd or 3rd weeks of June. The door panels are also dated in the 05-23 range. It has been a while since I had it apart and didn't record dates from the panels.
dstryr, since 1986.
[Re: dstryr]
#287058
04/14/09 11:43 PM
04/14/09 11:43 PM
sixbbl69
unless you bought your car new its only a guess anyway .
even then can an original owner prove that nothing was ever changed?
Only if you believe him.
