1971 thermoquad rebuild kit #2866710
12/30/20 08:43 PM
12/30/20 08:43 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
striking out online for a rebuild kit for a 71 340. i have one but need a second one. anybody have a source?
Re: 1971 thermoquad rebuild kit [Re: chrisf] #2866734
12/30/20 09:33 PM
12/30/20 09:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Off the top of my head, I've used allcarbs.com (Allstate Carb in NY) and Quadrajetparts (they also have Carter stuff).
There was recently a thread here on Carter parts, either in Q&A or Race section, some info there.
Re: 1971 thermoquad rebuild kit [Re: topside] #2866819
12/31/20 01:54 AM
12/31/20 01:54 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
thanks topside. ill check them out
Re: 1971 thermoquad rebuild kit [Re: chrisf] #2866841
12/31/20 07:56 AM
12/31/20 07:56 AM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
Rockauto shows part number 676A for the 71 carbs, and I think that is correct. I think that’s the kit I used on my 71 Cuda. It looks like they’re in stock at Rockauto, but there’s several on eBay too. Hygrade 676A.
Re: 1971 thermoquad rebuild kit [Re: BLACKHEMIRR] #2866965
12/31/20 01:27 PM
12/31/20 01:27 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
awesome. ordered two kits! thanks
Re: 1971 thermoquad rebuild kit [Re: chrisf] #2867414
01/01/21 11:32 AM
01/01/21 11:32 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What’s the difference between the 71 and later? I know the difference between the carbs but most kits I’ve bought have 9000 gaskets for every known carb in the box.
Re: 1971 thermoquad rebuild kit [Re: cudaman1969] #2867423
01/01/21 11:52 AM
01/01/21 11:52 AM
WV
Little Detroit Offline
WV
way to many differences to explain ,way many differences, metering rods ,floats, jets, and the 71 carb meters the air on the idle circuit not the fuel.
Re: 1971 thermoquad rebuild kit [Re: chrisf] #2867575
01/01/21 02:30 PM
01/01/21 02:30 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
did you ever check with the carb doctor ?? He is in Canal Flats, BC . . .
http://carburetordoctor.com/pages/about.html
Knowledgable and helped me out on a carb kit for my 64 Falcon 6cylinder . . . pretty sure he has everything . . .
Re: 1971 thermoquad rebuild kit [Re: cudaman1969] #2867649
01/01/21 04:13 PM
01/01/21 04:13 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
MANY years ago I'd read the '71 thermoquads were unique, they called it a "solid fuel" carb. I've never understood what they were talking about, still don't.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1971 thermoquad rebuild kit [Re: Little Detroit] #2867999
01/02/21 10:50 AM
01/02/21 10:50 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I wanted to know the difference in the kits not the carb? There’s Multiples of base gaskets and a lid gaskets, needles and seat, accelerator pump in each kit I bought.
Re: 1971 thermoquad rebuild kit [Re: cudaman1969] #2868008
01/02/21 11:02 AM
01/02/21 11:02 AM
WV
WV
well then try them , I just tried to explain the differences in the carbs which also includes the gaskets. there is a reason that they make a different kit because the parts in the other kits don't work.
Re: 1971 thermoquad rebuild kit [Re: Little Detroit] #2868219
01/02/21 08:13 PM
01/02/21 08:13 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What are these “parts” you talk of?
Re: 1971 thermoquad rebuild kit [Re: cudaman1969] #2868426
01/03/21 12:03 PM
01/03/21 12:03 PM
WV
WV
quit being lazy ,if you don't believe the answer to the question ,then do your own research . buy which ever kit you want and when you see that the parts don't line up you will then find out which ones don't work. its realtively easy to under stand, there is a kit made just for that particular carb and there is a reason for that .
Re: 1971 thermoquad rebuild kit [Re: Little Detroit] #2868510
01/03/21 03:13 PM
01/03/21 03:13 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
So, do you know? You throw something out there then when someone ask you specifics, you say look it up. This is an informative forum is it not?
Re: 1971 thermoquad rebuild kit [Re: cudaman1969] #2868695
01/03/21 11:27 PM
01/03/21 11:27 PM
WV
WV
what makes the difference you have already been told they are different , Well I gave you a heads up to help you move on towards repair, if its comparisons you want do you own research then you will have all the answers you want or you could just buy the correct kit for your carburetor and be done with it. Buy the way when it comes jetting and metering rods the are also different. It may be an information board but I don't have to do your research for you .
