Re: 1971 thermoquad rebuild kit
[Re: BLACKHEMIRR]
#2866965
12/31/20 01:27 PM
12/31/20 01:27 PM
Posts: 5,949 British Columbia
chrisf
British Columbia
Rockauto shows part number 676A for the 71 carbs, and I think that is correct. I think that’s the kit I used on my 71 Cuda. It looks like they’re in stock at Rockauto, but there’s several on eBay too. Hygrade 676A. awesome. ordered two kits! thanks
[Re: chrisf]
#2867414
01/01/21 11:32 AM
01/01/21 11:32 AM
Posts: 8,337 fredericksburg,va
cudaman1969
fredericksburg,va
What’s the difference between the 71 and later? I know the difference between the carbs but most kits I’ve bought have 9000 gaskets for every known carb in the box.
[Re: cudaman1969]
#2867423
01/01/21 11:52 AM
01/01/21 11:52 AM
Posts: 704 WV
Little Detroit
WV
way to many differences to explain ,way many differences, metering rods ,floats, jets, and the 71 carb meters the air on the idle circuit not the fuel.
[Re: chrisf]
#2867575
01/01/21 02:30 PM
01/01/21 02:30 PM
Posts: 2,922 Calgary, Alberta Canada
a12rag
Rockauto shows part number 676A for the 71 carbs, and I think that is correct. I think that’s the kit I used on my 71 Cuda. It looks like they’re in stock at Rockauto, but there’s several on eBay too. Hygrade 676A. awesome. ordered two kits! thanks did you ever check with the carb doctor ?? He is in Canal Flats, BC . . . http://carburetordoctor.com/pages/about.htmlKnowledgable and helped me out on a carb kit for my 64 Falcon 6cylinder . . . pretty sure he has everything . . .
[Re: cudaman1969]
#2867649
01/01/21 04:13 PM
01/01/21 04:13 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
What’s the difference between the 71 and later? I know the difference between the carbs but most kits I’ve bought have 9000 gaskets for every known carb in the box. MANY years ago I'd read the '71 thermoquads were unique, they called it a "solid fuel" carb. I've never understood what they were talking about, still don't.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Little Detroit]
#2867999
01/02/21 10:50 AM
01/02/21 10:50 AM
cudaman1969
fredericksburg,va
way to many differences to explain ,way many differences, metering rods ,floats, jets, and the 71 carb meters the air on the idle circuit not the fuel. I wanted to know the difference in the kits not the carb? There’s Multiples of base gaskets and a lid gaskets, needles and seat, accelerator pump in each kit I bought.
#2868219
01/02/21 08:13 PM
01/02/21 08:13 PM
cudaman1969
fredericksburg,va
well then try them , I just tried to explain the differences in the carbs which also includes the gaskets. there is a reason that they make a different kit because the parts in the other kits don't work.
What are these “parts” you talk of?
#2868510
01/03/21 03:13 PM
01/03/21 03:13 PM
cudaman1969
fredericksburg,va
quit being lazy ,if you don't believe the answer to the question ,then do your own research . buy which ever kit you want and when you see that the parts don't line up you will then find out which ones don't work. its realtively easy to under stand, there is a kit made just for that particular carb and there is a reason for that .
So, do you know? You throw something out there then when someone ask you specifics, you say look it up. This is an informative forum is it not?
